first time start up
Bonehead's brother
Active member
Sep 17, 2011
30
Naples, Florida
So I have a 383 SBC that should make about 360hp so it is not a high compression motor. I am trying to start it up. I know how to put the hot battery cable on the correct stud of the starter and jump it with a screwdriver. I have the small JEGS starter-
With a full charge on the battery, I can get the motor to barely turn over. I mean barely, half a rotation maybe. Tried a few times, starter got hot. Motor never spun enough to fire. What is going on?
Pull the spark plugs and see if it turns over. Or, with the plugs removed try turning it over with a breaker bar and socket on the crankshaft balancer bolt.
more info
engine turns easy enough with the plugs still in using a standard half inch ratchet so it would seem the engine is ok. I am using jumper cables for battery cables. I am thinking these are not thick enough and/or too long, and messing up the amount of current actually getting to the starter. Could this be right?
Yep, you got it. Jumper cables will run a starter on the ground, but not enough amperage to run one and turn over an engine. You're gonna have to hook up a real battery cable , hot and ground, to get it to turn over.
