thom
I bought a fuel gauge kit from NAPA that includes the gauge and sending unit as well as the mounting under dash bracket. It worked for about 3 weeks then the needle fell to below EMPTY and stayed there. They gave me a new gauge but that didn't fix it. After some more checking I figured the problem must be in the sending unit. I replaced the sending unit and that didn't fix it either. I checked the wire from the tank to the gauge and it burned the test light but not full brightness so I figured the new gauge must be bad, so I tried another gauge. Still not working. However, when hooking the volt meter to the wire at the gauge it reads the same as when hooked to the sending unit on the workbench, with the sender at 3/4 full, which is what the tank has. I'm puzzled. It sees that all the parts work correctly on the workbench but not on the truck.![Confused :confused: :confused:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
