Another Ford
Nice work Lowbud!
Thanks!!!
More work.in the last pic, I'm holding up the gas flap door, which is bronze. This will be frame color and wheel color
Small update. The truck is being tore down to be sent off for coating of the frame. I will do rust repair and other odds and ends while we wait!
Frame is done and ready to go for powder coating.
Now I'll start rust repair and firewall painting
Rust repair!!
Thanks, the back driver side wasn't so fun. I ended up having to cut it into 7 pieces to make line up right. Way to much welding. I hate using filler, but I can't get to some of this to hammer and dolly it. So I might have to use some:mad:
It either lined up at the door opening or behind the cab. Not both at the same time. I kept the side at the door un cut. I did all the cutting and welding behind the cab.
We're driver side patch panel all roughed in.
Thanks guys. Got one more little patch panel to do on the front passenger side corner and then the metal work is done on the cab. I will probably strip the firewall and get it painted and then do the patch panels on the box. Still have body work to do on that back driver side corner but I will probably get everything else done first
Firewall primed and painted! Also got the back cab corner 97 % done.
