Electrical... Talk & Q&A! Electrical Q&A.. The shocking truth, tips, tricks & more! |
Thread Tools | Display Modes |
![]() ![]() Click on DSCF and it will load it on flickr |
That happened on my tractor & it was because the clip that holds the cap down wasn't doing it's job. I bent it a lil... problem solved! Does the engine run fine otherwise? Probably not a warped shaft but that is possible but maybe a worn bearing?!?
![]() BoB
Rust... Mother Nature's paint job... don't fool with Mother Nature! RRR on Facebook RRR on Twitter Wanted: Ratty '35 Olds coupe! |
Tripper, it's a little hard to see, but the entire unit is moving, not just the cap. When you look at the base where it goes in the block, you can see the shaft wiggling, and you can see oil bubbling under it.
Yeah, it starts at nothing and runs great! I'm concerned it won't last long though wiggling like that. |
The shaft is bent
Thanks Old Iron for confirming what I thought.
The whole bloody thing is waggin' around... I wasn't expecting that!
Why does it leak at the base? Is it loose in the bore? Could it be riding tight on top of the pump shaft? I'm not disagreeing with Old Iron for a minute, just stunned and doubly curious to see how bad the shaft is... .
- The distinction between psychological illness and creative thinking is wafer thin - 1937 Chevy Coupe 1938 Chevy Sedan Photo Posting and Resizing |
I'd pull the dizzy out clamp it in a vice and turn it by hand with a dial indicator on the end opposite the end I was turning. I'd think that would verify it being bent.
Hot things look just like Cold things ![]() Offroadrolls build: http://ratrodsrule.com/forum/showthread.php?t=23696 42 Chevy PU build: http://ratrodsrule.com/forum/showthr...ht=42+chevy+pu |
had one do it on a 300 cid ford, it got worst and then it eat the gear off the dist. shaft. don't know if it got the cam or not cause the truck was totaled and we kept driving it. as a matter the ranger i drive is totaled due to a hail storm years ago. offroad got it and if you need a indicator let me know.
![]() Quote:
It looks like it's riding the cam gear up, then back down. I was shocked when I saw it, too! I know it won't last like that. I'm not going to run it much. I sent a link to the video to the eBay seller to look at. I hope they know what they're looking at. Supposed to be warrantied for a year, so maybe they'll just send me another one. If not, I'm out $50. I figure though they will make it right, they don't want eBay and paypal to get ahold of them. |
![]() Quote:
![]() I'm also curious to know what the deal is too ![]() ![]() ![]() ![]() |
Bookmarks |
Thread Tools | |
Display Modes | |
