ol' rusty
Rollin!
looks super great! [cl that motor is clean!
I ordered my mobsteels friday, what tire sizes are you running?
They are 20x11 and 20x9
But I had to reorder the rear ones because they are too tight against the body. I don't want them to rub. They are very well-made products
haha nice, but what TIRE sizes are you running on the 20x11 and 20x9
by the way I chose 20x9 and 20x8, with enough backspace for a good lip on both.
I have ordered mobsteels in the past and pam and adam are dynamite human beings.
More goodies
So the cab is bolted down in the back, but the front had to be re worked due to the floor being a different year. I built a paper version last night. Not 100% happy but it should work. I will probably wrap a small 1" tall piece around the front to connect the outer side to the front piece
Final product. Need to finish attaching it then add some seam sealer to keep the inside clean. I weld through primed the inside of it so it should stay rust free. It's really hard to see, but there is alot.of work in that ugly thing!!
13 hrs later we have a new trans tunnel, finished body mounts, hole in the back of the cab for the drive line loop is covered and the trans has been pulled and reinstalled with the hydraulic throw out bearing! Getting closer!!
Got the cab almost done. Have a few more areas along the fire wall
