Go Back   Undead Sleds / Rat Rods Rule - Hot Rods, Rat Rods, Sleepers, Beaters & Bikes... since 2007! > Tech Tips!
Old 05-15-2019, 09:31 AM
Default A penetrating oil tip!
Ok... don't know if you've ever seen Farm Show magazine... it's a lil rag of articles of kool & krazy things people build on the farm etc. They did a test to see what penetrating oil works best.
Here are the results...
One of the most popular articles FARM SHOW has ever run was a short piece reporting on the results of a test of penetrating oils in Machinist’s Workshop magazine (Vol. 34, No. 3). The winner turned out to be a home brewed 50/50 mix of automatic transmission fluid and acetone. It beat out Liquid Wrench, WD-40 and other popular “rust busters”.
https://www.farmshow.com/
Old 05-15-2019, 10:54 AM
I read about that about a year ago and their findings are the best.
I actually think there was a post about it on here.
Old 05-15-2019, 03:06 PM
von-zipper's Avatar
von-zipper von-zipper is offline
Thanks, I'll give that a try!
Zipper
Old 05-16-2019, 12:03 PM
Blue Eyed Devil's Avatar
Devil's Advocate
It's the only thing that freed up the stuck torsion bar adjusters on my '58. Keep a squirt bottle full in the shop at all times!
Old 05-16-2019, 04:26 PM
soltz's Avatar
soltz soltz is offline
The Rat Captain
Thumbs up Good Info
O.I. is right, I also remember reading this but can't tell how many years 2 or 3 anyway.
Be Safe
and
Be Creative
Old 05-16-2019, 08:10 PM
Neto Neto is offline
Does the trannie fluid prevent the acetone from evaporating, or does it need to have more added from time to time?
Old 05-16-2019, 08:34 PM
DozerII's Avatar
DozerII DozerII is offline
Billy posted a while back here https://ratrodsrule.com/forum/showthread.php?t=35658
Glen
Old 05-20-2019, 07:44 PM
sgtpontiac's Avatar
sgtpontiac sgtpontiac is offline
Older, Wiser and Still Buildin'
Only thing that even comes close is Kroil.... and honestly I'm not convinced that it isn't the 50/50 mix of TF and Acetone...Kroil is just too expensive to be spraying all over....
My 96 GMC Rat Buildbuildthread
Old 05-28-2019, 10:18 PM
everything old is new again.
we were using this 50/50 acetone/atf mix way back in the 70's as a starting fluid, rusted cylinder cure.
pour it down the carb while turning motor, if it would move or just pouring as much as we could get in thru the spark plug hole, let soak, repeat.
scary good results.
Old 06-17-2019, 08:39 AM
wjcgasser wjcgasser is offline
Picked up a 1964 polara last weekend was parked in a cattle shed in 1994 put a four foot bar on the front of crankshaft it wouldn’t move pulled the plugs poured in atf and acetone two days hit the key spinning free should have checked for seized valve bent one pushrod
