Go Back   Undead Sleds / Rat Rods Rule - Hot Rods, Rat Rods, Sleepers, Beaters & Bikes... since 2007! > Fuel systems Q&A
Fuel systems Q&A Carbs, injection, tanks, lines, pumps, everything fuel system related!
Old 05-08-2019, 10:39 AM
Skip's Avatar
Skip Skip is offline
Default Carb Spacers, Are They A Good Idea?
When I was putting the new manifold on my 305 Chevy engine, I didn't have any studs handy, so I used a two inch spacer that I could install with quarter inch bolts that i had handy. The spacer is the wide open kind. Yesterday, I read that this is good for high end power, but I also got the impression that it is not so good for cruising, which I know will be the primary function of this vehicle. That said, the installation looks cool, but will it be the best fit for what my truck will be doing. Or am I just worrying about nothing?
39 Ford PU Build. http://ratrodsrule.com/forum/showthread.php?t=36459
1928 Ford Tudor Build http://ratrodsrule.com/forum/showthread.php?p=538231#post538231
The thing about a '39 Ford pick-up is that that ugly grille kinda' grows on ya' after a while.
Not taking anything too seriously.
Old 05-08-2019, 11:31 AM
MercuryMac's Avatar
MercuryMac MercuryMac is offline
Builder Junky!
This is just an opinion, Skip, but I think you're worrying about one horsepower difference, that you won't even notice. If it looks cool, works good and is what you had, run it.
As you mature, Skip, you'll find that some coffee-shop wisdom should be sifted through and culled aggressively. You must be too dang young, if you worry about insignificant power loss when you have fifty horses in excess in a hotrod.
Go For It.
Old 05-08-2019, 11:39 AM
Skip's Avatar
Thanks, MM. I'll leave it as is for now. See what happens.
As for maturing, at my age, I am already in regression.
Old 05-08-2019, 02:34 PM
You know the rules... photos or it didn't happen!
Go For It.
What he said!!!
Old 05-08-2019, 03:07 PM
Yep, I triple X this one
Old 05-08-2019, 03:09 PM
sgtpontiac's Avatar
sgtpontiac sgtpontiac is offline
Older, Wiser and Still Buildin'
Yep.... got my vote that you won't feel the difference...
My 96 GMC Rat Buildbuildthread
Old 05-08-2019, 05:01 PM
Skip's Avatar
What he said!!!
My new camera batter is in the mail. Pics later in the week. I promise.
Old 05-08-2019, 05:52 PM
smallfoot's Avatar
smallfoot smallfoot is offline
The only time I ever had to use a spacer, it was to correct a fuel heating issue. I had one that occasionally would vapor lock and a spacer made it quit for me. I never noticed much difference on how it ran...
Old 05-11-2019, 03:53 PM
Skip's Avatar
Finally, My camera has a battery. Here is a shot of the $25 Carter sitting on top of the $5 spacer.
BTW We fired it today, and it actually works.
Old 05-12-2019, 11:06 AM
I-R-POPS's Avatar
I-R-POPS I-R-POPS is offline
''Rusty Mopar Slacker''
Run it and if the carb works forget it. just my 2 cents worth.
POPS
'52 WILLYS JEEP PICK UP
'47 DODGE SHOP TRUCK
'48 DODGE PILOT HOUSE RAT
MIND OVER METAL
SO LITTLE MIND IT DON'T MATTER
