hillbillie hotrods
Whats the best caster degree to use on a 4" dropped axle with a cross over spring and trad. side steer , the spring is hung off a spring perch that is mounted to a 3" round tube .
When i'm going to weld the perch in should it be on 0 degrees or the same as the caster degree
Thanks
Thanks
