Builds! Post your project here... show us what you're up to! Please Note: This section is for "Builds" ONLY! |
Thread Tools | Display Modes |
#2581
![]() Quote:
My 455 Buick powered '46 GMC Build Thread My '46 GMC on Photobucket --------------------------------------------------------------- When you don't know what you're doing, it's best to do it quickly. And when I’m gone, you can call me foolish but hopefully not boring. I will have lived. The more I learn about women, the more I like my car. |
#2582
![]() Quote:
![]() No worries about the pics. Once I set the body down on the frame I will know better what has to go. I suspect the cross member ahead of this one will be in the way. It goes across the gas tank and is a place for the muffler hanger. It also sticks up above the frame rails. I'm calling this part of the program done. ![]() ![]() ![]() ![]() ![]() ![]() PS Por 15'd and then undercoated. I sprayed the Por 15 this time. Should have done it that way to begin with. ![]() Keep on keeping on... Torchie |
#2583
looking good all in one color!
He who dies with the most toys wins
#2584
You're gaining on it
#2585
Man I bet your happy to see that chapter over with.
Glen My 29 Essex Build http://ratrodsrule.com/forum/showthread.php?t=34026 Don't give up, it's far too much fun once you can drive it. |
#2586
dont worry about the crossmember too much, its just the ext cab crossmember, the std cab short and std cab long have separate crossmembers but the ext cab is one piece.
you can weld in a rear crossmember and then trim that one to just the upper shock mounts if you want, or figure out another way to mount the upper shock. looking good torchie! |
#2587
![]() Quote:
Thanks for clarifying. I haven't been under an extended cab S10 so that makes sense that it's an extended cab crossmember. Good info!
#2588
Thanks for the info guys.
The rear cross member shouldn’t be an issue with the spare tire well out if the way. Which, as I posted earlier, has to go because it will hit the side frame rail. Going for more stripping if the S-10 tomorrow if I can. Torchie |
#2589
#2590
Is this the distributor you need Torchie? Look at the plugs and see if they match. Came from a TBI 4.3 V6. If it is, let me know and I'll get it on the way.
2023 calendars available here: https://www.zazzle.com/2022_fat_fend...46680814180838 |
Bookmarks |
Thread Tools | |
Display Modes | |
