1957 Gerstenslager High School Shop Build
got the IRS trimmed to fit the boxed rails
going to set the pinion angle then weld
did a visual for the front frame mods
we will make better patterns after we figure out the direction we plan to take
we raised the CV up into the frame about 4 inches
this keeps our camber correct at ride height
I thought about that same setup for my car. It's wider than a same year Ford, so it would probably fit pretty good. Still might do it one of these days.
The crown Vic is easy
It is a bit wide for a lot of applications
But it’s working out good for this van
The rear is easy too, just a little more fab
