1926 Dodge Brothers
This is just a brief update.
I picked up my frame parts from the laser cutter Wednesday. :D
I didn’t get very far tacking them up, but you’ll get the idea of where it’s headed.
Nice !!! [;)
Thanks!
We’ve had family in visiting since Thursday, so it’s been a trip trying to find time to get anything done on the Dodge. I welded on the front frame rails a little, just need to box them top and bottom. [;)
Hopefully I can get some more done this evening.
Well one of the two out of town guests left yesterday, so I was able to sneak off for a couple hours. :)
I got most of the fill plates cut to box the frame in and also made a new “blank” for our sun visor to send to the laser cutter. (They screwed up the last one, so this is take two on the visor :mad:)
I then started getting a couple of the sections tacked together, rear and cab. :D
Looks great! You're almost there. :)
How do you like the tolerances of the laser cutting process?
The laser parts are awesome, but being the typical engineer, I didn’t adjust my drawing properly.
They made the parts spot on and I had to clean up all my tubes so they would fit. (See pic)
If I do it again, I’ll add a 1/64” to all the hole dimensions.
It’s been difficult to get my son to agree to any paint, but he did get some color on a couple parts today! [cl
WOW, that frame is looking awesome and those painted pieces too! Love that color.Cant wait to see this thing come together.Very cool and I dont know why you were worried about this being your first build, looks like you done this stuff for years.
Thanks man! I really appreciate that. :)
Got the visor piece to the laser cutter last night and they burned it while I waited, turned out great. :D
Looking GREAT!!! Love the visor!!! I have a couple antique "2 man" saws... I'm planning on using one of them for a visor. I guess great minds think alike...
Hahaha, I hear you. I supply prints to two different vendors. One is a cabinet maker and the other one is a water jetter. At first, it was kind of challenging to predict how far off each one of them was, but now I've gotten it nailed down. It's such a relief when hand-made wooden parts and water jetted steel parts go together on the first try, LOL.
The color looks great. The first thing that came to my mind was Jimi Hendrix. [cl
Hope everyone had a great 4th of July weekend! :D
I spent most of mine getting my frame welded up. (20 hours of welding, leveling, grinding, re-welding, re-leveling, etc.) [;)
I just wanted to get it ready to place under the car and figure out where the motor mounts, trans, rear end and so on would all go. We’ll have a lot of brackets and welding to do, so I didn’t finish welding the frame solid yet.
Friday I got our frame platform that we use to weld up our machine frames leveled up and ready. This made it a lot nicer to get the frame pieces lined up and keep them square and level. :)
The front rails had warped slightly so I clamped them to the platform and boxed them in, this straightened them back out.
I then got the back half squared and clamped down, then lined up the rails in the proper position to the back half so I could get it all connected.
I had to stop several times to re-level and re-square everything, also had to use a bottle jack to spread the rails back. :mad: (A tube frame would have been so much easier!)
After getting all the sections together I boxed the rest of the frame in. [;)
Still looks like Doctor Frankenstein welded it, :eek: but that will all get cleaned up later. [ddev
frame
interesting frame, is it gonna be strong enough with all the holes in it
my concern is the flex it may have during a hard take off or hard cornering.
mabe even in a few years stress crack start.[S:eek::confused:
looks nice though,,,,,,,,,
Later:cool:
Later:cool:
Should be, each hole has a tube welded inside it (Welded inside and out) that ties the walls together; it actually should be a little stronger than just a plain tube.
As far as cracking…man I hope not! :eek:
