Old 12-23-2013, 09:48 AM
Default 48 GMC 5 window
This 48 GMC is the pickup I got from John as part of the trade for my 40 Pontiac convertible I was building.
I'm gonna do a restomod. Sorry with this being a 5 window, no chop on this one.
Factory length short bed
Mustang ll, tubular upper and lower control arms, 2" drop spindles coil springs with shocks, disc brakes and 5x4.75 bolt pattern
Chassis Engineering rear leaf kit
Either a 5.3 Vortex or a LS1 depending on which one I come up with first.
Behind it will be a 4l65e tranny and a 3.73 disc brake limited slip 8.8 Ford rearend
Here's where it starts
Cab
Rusted cab corners
Driver side inner and outer
driver side new
Passenger side outer only
Passenger side new
Floorboard out
I'll have the floorboards in today and post up pics this evening
Old 12-23-2013, 10:51 AM
54IrrationalHarvester's Avatar
54IrrationalHarvester 54IrrationalHarvester is offline
Default sweet
Love them 5 windows. You have talent so I can't wait to see this.
I wish I could find cab corners for my R-102. I may just find something close enough to shape and hack them up to fit but they typically are not very cheap.
I assume a strecher wouldnt work to curve them because of the radius on the bottom instead of a sharper corner.
anyone ever make a wood buck and hammer them out?
Real Men build their Dreams
Old 12-23-2013, 02:33 PM
Bamamav's Avatar
Bamamav Bamamav is offline
Love those five windows!
Old 12-23-2013, 06:16 PM
Default Floorboards
I don't know where you could find the 54 IH cab corners. Like you said, might be able to use something else that would be close.
I had a lot of traffic in the shop today but, still was able to get the floorboard in
Old 12-23-2013, 06:23 PM
I-R-POPS's Avatar
I-R-POPS I-R-POPS is offline
''Rusty Mopar Slacker''
Pretty clean old cab. A great jumping off spot
I like being able to see out the rear corners
Old 12-23-2013, 07:22 PM
Texaswino Texaswino is offline
When I lowered the lid of my 48 Thriftmaster 5 window, I made new corner glass by laying 1/4 Lexan I had cut in the correct shape, over the original glass in a kitchen oven on 250 degrees until the Lexan melted and took the shape of the original glass. Looked like original. Sounded different if tapped on.
Old 12-25-2013, 09:29 AM
Default Toe kicks
The kick panels had a line of rust through them so, I made a pair yesterday and installed the drivers side.
I'm going to leave the air vent in the side of the drivers fender for ventilation.
Rusted
New panel, one for each side
Positioned on the passenger side
Installed on the drivers side and left the internal louvers
As soon as I get the passenger side welded in I'll grind the welds smooth
Old 12-25-2013, 09:30 AM
Nice stuff, looking good.
Old 12-25-2013, 04:20 PM
Looking good, nice work on the floor and panels!
Old 01-01-2014, 12:19 AM
Default nice panel work
nice job on the panels.
mine are a bit worse off.
