Old 08-11-2013, 01:21 PM
Strange willy Strange willy is offline
Default AB-ie has commenced
So I bought a 31' Willys C133 pickup off eBay in April of 2012 with the intent of building a mid-engine rat, the body is real straight with only a few small rust holes, the wood is junk and it was held together with wire when I picked it up out in Parker, Co. There were less than 3000 trucks made in 31' so pictures or parts are extremely hard to find.
So I spent the rest of the year staring at this body stuffed in my garage trying to figure out the design and gather parts, my girlfriends cousin happened to have a mid 80's Jag that I robbed the rear axle out of and a 500 ci/Th400 combo out of a 72 caddy. I chose to go with IFS in the front to match the Jag IRS in the rear but I don't have $4000 to buy the Heidts open wheel kit that I really like the looks of, so with a bunch of emails between a few company's I have enough info to build my own. With the living room in our apt filling with boxes of parts in February I feel I have enough stuff to start.
Lower A-arms 1 1/8" Dom with Chevy ball joint
Upper A-arm 1" Dom with Dodge ball joint
I'm using 69' Camaro drop spindles so I had to ream the upper holes to make the Dodge ball joints fit.
Old 08-11-2013, 01:35 PM
GJunktionMike's Avatar
GJunktionMike GJunktionMike is offline
Something's wrong with that boy!
Very nice start.
Think I'm strange, you should meet the person that occupies my mind
Old 08-11-2013, 02:08 PM
Frame rails are 2x4x3/16, width is 27" wide pinched to 20" at very front to match the grill.
Trying to figure out how much Z to make the frame level, static ride height designed for around 4-5
Old 08-11-2013, 02:10 PM
skull's Avatar
skull skull is offline
''SARCASM: just one of his many talents.''
Thumbs up shocks?
what shock/spring set-up and how will they mount?
looks good
Later
my opinion only, valid where prohibited, for official abuse only.
1928 maxwell hybrid build/drag car
http://ratrodsrule.com/forum/showthread.php?t=37455
1948 dodge truck in deceased son's memory.
http://www.ratrodsrule.com/forum/sho...odge+truck+son
1930 2dr mopar.
http://ratrodsrule.com/forum/showthr...ht=30+mopar+dr
Old 08-11-2013, 02:18 PM
Jag IRS mounted
Building motor mounts
Single u-joint between tranny and rear axle. Pinion angle on the Jag is 0* motor is set at a 2* angle.
Tranny crossmember
Old 08-11-2013, 02:20 PM
Skull I'm using the factory Jag coil overs for now till I can figure out what this thing will weight.
I will use coil overs on the front as well.
Old 08-11-2013, 02:31 PM
Body and frame finally met in May!
Making vroom vroom noises!
Yep nothing fits right
Finding a starting point, skeletal steel is 1x2 and 1x1 1/8 wall.
Old 08-11-2013, 02:38 PM
Since this body was basically in pieces when I bought it and most of the wood is gone or junk trying to find the natural fit of the panels was kind of a chore. This will bite me in the butt later on!
1x1 bent in our 50t press
Old 08-11-2013, 03:09 PM
skull's Avatar
Lightbulb like
looking great
l think these wheels or this style of wheels would finish it off perfect.
(personal choice of wheels)
Later
1930 2dr mopar.
Old 08-11-2013, 03:10 PM
Body is channeled 4" over the frame.
Laying flat
Grill is a bit tall gonna have to shorten that up.
That is a Pines winter grill with the close able shutters
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
