307 chevy camshaft selection?
tighter lobe center yeilds greater overlap
Overlap allows the exiting exhaust to impart momentum to the intake charge by drawing it down and out the exhaust before the exhaust valve closes.
When the exhaust valve closes the intake charge stacks up in the cylinder under pressure before the intake closes.
This increases breathing efficiency at higher rpms but wastes fuel out the exhaust.
This is why the 302 V6 in my 1963 GMC always smelled like raw fuel at the tail pipe. The engine was a big truck engine designed to work at max rpm not designed to be lugged and the high overlap is how the 8:1 compression cylinder got filled well.
people called them boat anchors when they didn't know how they were intended to be driven. NAPA machinist told me this. I had complained it was a dog and he asked me if I was using the "gold" points ir the cheap points. he told me the Gold ponts have a tigher spring and keep point bounce at bay at the upper rpm's then went on to tell me how the engine was tuned by GM to be wound out before it was shifted.
After installing the gold points and driving it like that It was awesome.
Truck would do over 120 mph with 3:08 gears and a 4 speed now that the ignition system was not shunting the engine before it got into it's powerband.
Lift- increases the "area under the curve". the higher you lift the valve past the port's maximum flow rate, the more TIME the valve is open at max flow
Duration- The amount of time the valve is open
What you want to do with a small valve engine is to increase lift and duration as much as you can without increasing the stock overlap. Overlap is where your re going to lose mileage.
At some point no more lift or duration will cheat the small port so you don't need to go more than is effective. plus more lift requires stiffer valve springs to prevent valve bounce ie "float"
the higher the valve is lifted the more energy that is expressed when it closes
All that energy has to be stopped at the closing by valve spring pressure or it will vibrate the spring and lift the valve back off the seat when it is supposed to be closed.
Increasing duration actually slows the valve speed and helps float.
specialty cams are out there that open the valve fast and set it down slow.
stiffer valve springs and high lift require screw in rocker studs OR you can drill through the head casting into the stud and drive in a roll pin to prevent them from pulling out.
for good mileage I'd pick something between a 116 degree and 112 degree lobe center.
for keeping stock springs and valve train you can go up to around .500 lift
Anything over 280 degrees duration in a flat tappet is going to start dropping vacuum at idle and run thumpy but the powerband will be moved up the curve.
With the small valves the engine is going to run out of wind at about 4,000 to 4500 rpm so worrying about over revving is not much of an issue if you use the ARP rod bolts
Anyone driving it will feel the power drop off and there will be no incentive to push it harder
What your going to be doing with your camshaft selection is improving power between 1,000 and 4500 rpm.
On a truck you are going to need a 600 cfm or larger 4 barrel or it will be weak on a downshift pass. A 4 barrel on a pass without downshifting just bogs out.
But a 2 barrel driven like a farmer would be fine.
Throw a set of 283 power pack heads on there and you will keep good compression and need a 4 barrel.
or you can have 194's put into the 307 heads. the ports themselves are not bad.
The 307 is basically a 283 stroked with a 327 crank
The 305 has a smaller bore with a 350 crank so a good set of 305 heads with 194's will work good too
2:02 heads probably won't fit
327/350 heads will drop compression and probably
overhang the cylinder
you could throw a set of 305 vortec heads on there with a tuned port injection setup!
Cam, timing set, and gaskets is all I am planning on.
If it takes more tan that...I'm swapping in a 4.8 or 5.3 LS truck motor.
the last 307 i built had 305 ho heads with the 1.88 intake valves and the comp cams 270 mag cam. we port matched the heads and blended them. he installed 1.5 shorty center dump headers and it was a very spirited little motor. it was in a 65 or 66 chevy truck that had 3.72 gears so gas mileage was out the door to begin with but when you stepped on the loud peddle it came alive. i got most of the stuff collected to build another but this time i think i'll go with the 280 mag cam.
I ran a Comp Cams 268H cam in a stock 307. I performed surprisingly well. It was in a 62 nova, fender well headers, performer intake and carter 400 cfm carb. Had a turbo 350 and 308 rear gear. I drove it in SoCal for about a year doing field service work ~ about 40k miles. averaged about 14/15 mpg, could squeeze 18 if I really tried.
As much as I love the sound of a healthy small block, I think (kinda, right now) I'm gonna go small on the cam. I am going to try and build it so that it makes so much torque down low that it can't be stalled out by my daughter ....or be over revved.
from what I have read, the .390/.410 is stock for this motor and the .398/.420 is the RV cam.
Elgin list two cams smaller than stock. I'm guessing the two small cams are for big trucks/moving vans?
Elgin, Hyd. Flat Tappet Cam Kit, Chev SB, .368/.398
Chev SB
Lift: .368/.398
Duration: 250/260
Duration @ .050": 184/194
Lobe Separation: 104 LC
Improved bottom & torque. Low rpm only.
Elgin, Hydraulic Flat Tappet Complete Cam Kit, Chev SB
Chev SB
Lift: .385/.408
Duration: 258/269
Duration @ .050": 190/200
Lobe Separation: 112 LC
Smooth idle. Excellent torque, good economy.
Chev SB
Lift: .390/.410
Duration: 258/269
Duration @ .050": 194/203
Lobe Separation: 116 LC
'70 350/300HP (GM #3896929)
Chev SB
Lift: .398/.420
Duration: 260/270
Duration @ .050": 194/204
Strong torque, smooth idle.
Sorry Flipper, I don't remember, and can't find a record of the specs of the cam I bought. I always two steps milder than everyone else.
The advertised duration is just a selling tool.
The duration @ .050 is what you want to pay attention to.
Everybody has their favorite combo and so do I. I use an Elgin hydraulic cam with 204 int 214 ex @ .050 for an everyday driver street cam.
It'll pull off idle to around 4,000 to 4,500
Cam and lifters from Competition Products is $99.95 free shipping
http://www.competitionproducts.com/...20_443-112-LC/productinfo/E923M/#.VbUlr7Vp3gw
Specs:
Part Type: Camshaft
Application: Chevrolet SB V8 262, 265, 267, 283, 302, 305, 307, 327, 350, 400 1955-2002
Ignition Firing Order: OE (1-8-4-3-6-5-7-2)
Cam Style: Hydraulic Flat Tappet
Basic RPM Range: 1500-4000
Manufacturers Description: Improved power. Good low and mid-range.
Intake Duration @ .050": 204
Exhaust Duration @ .050": 214
Advertised Intake Duration (@ .006"): 278
Advertised Exhaust Duration (@ .006"): 288
Intake Valve Lift with OE Rocker Ratio (1.50): .420"
Exhaust Valve Lift OE Rocker Ratio (1.50): .443"
Intake Lobe Lift: .280"
Exhaust Lobe Lift: .295"
Lobe Separation Angle: 112 Degrees
Intake Centerline: 108 Degrees
Lifters Included: No
Small Base Circle: No
Cam Gear Attachment: 3-Bolt
Valve Adjustment: Zero Lash Plus ½ Turn
Manufacturer: Elgin Industries
Manufacturer's Part Number: E923
Specs:
Part Type: Camshaft
That is one of the cams that I had picked in post #5
According to an on-line calculator, it said that I will be turning 2700 rpm at 70 mph using a 4 speed (1:1 high gear) and 3.70 diffs and a 32" tire. Going to a 35" tire only drops it to 2500 rpm. Does this sound right?
I don't think I'm gonna get real good mileage no mater what.
32 divided by 35 = 0.914285714
1 minus 0.914285714= 0.085714286
round 0.085714286 to the hundredths place 0.09
times 100 to convert to percentage = 9%
There is 9% difference between a 32 inch and a 35 inch tire.
That will cause a corresponding 9% change in any other part of that equation
9% change in tire size is equal to a 9% change in gearing or a 9% change in rpm or torque.
9% accross the board.
I went from 4:11 to 3:22... A 20% change in gear ratio resulting in a 20% change in rpm and a 20% change in highway gas mileage from 10 to 12.
The percentage of change you introduce into any one component if a mathematical function causes a corresponding change of the same percentage in every other component of that equation.
I don't need to do a complex calculation to figure out what the change in rpm or speed will be after a gear or tire change. Don't need to know how many feet in a mile or tire circumference
I simply figure out the percentage difference in what i' have and what I'm changing to and that applies to everything else
in a 283 the 204-214 cam will be on the rough idle side and rev like crazy, a very good choice.
used a very similar cam in a 350 powered pickup and loved it. got 15-16 mpg towing 12,000 lbs and still had power to spare.
sounds like the one for your SBC.
I think I've talked myself into swapping in a 4.8 ls motor. No flat tappets to wipe out and it has much better heads...and EFI.
