Lincoln
Several different versions, depends on how it was set up originally. I think it is a good unit, but it may be a base model or it may have all the bells and attachments.
This is whats in the ad.
The Invertec V350-PRO is a versatile, multi-purpose, multi-process power source that's lightweight and portable. Available in construction, factory, advanced process and factory rack models, the V350-PRO is capable of doing virtually any job, whether in the shop or on the construction site. The V350-PRO is capable of stick, DC TIG, MIG, Pulsed MIG (requires Advanced Process Panel), flux-cored and arc gouging, making it the most versatile inverter power source in its class. And it's built tough to handle the rigors of harsh environments.
Advantage Lincoln
• Economy Construction Model
• All input voltages and frequencies are both single and three phase rated — no phase derating necessary on single phase.
• 5-425 amp output range for all recommended processes from TIG to arc gouging.
• Input voltage from 208-575 — this one machine is capable of running on virtually any input power supply.
• 50 and 60 Hz operation — can be connected anywhere in the world.
• Touch-Start™ TIG for contamination-free starts.
• 87% efficiency — low power consumption for energy savings.
Additional parts...
Power Source
Invertec® V350-PRO
Construction Model K1728-5
Wire Feeder
LN-25 PRO K2613-1
Wire Feeder Optional Features
Work and Wire Feeder Power Cables and Work Clamp K1803-1
Drive Roll Kit -
5/64" Solid/Cored Wire KP1697-5/64
Magnum® Accessories
350A FCAW-SS Gun
(15 ft, .062-3/32") K126-2
I think it would probably do anything you ever wanted. But you have to know what it comes with. Maybe just arc leads. Or Tig torch, and arc leads. If it comes with a gas hook up, and wire feed too then you have it all covered.
Makes you wonder what the guy was doing with it without any leads? Are the serial numbers still there?:D
He bought one of those storage garages that people dont pay for and then they sell the stuff at auction.
He also has a
Miller S22A
Miller XMT200
Miller Thunderbolt 225
Well all you have there is the main power supply for the program. You will still need to acquire the MIG and Tig assemblies to make it a complete welding unit. If you are picking it up for less then $500, its' a start in a better direction. Happy hunting and good luck. Maybe one of those other units is supose to accompany that power supply?
Maximo
