BigIrish
I think the oil & diesel combo is the same principle behind that "engine flush" stuff at the auto parts store. Supposedly OK as long as you are just running it in neutral with absolutley no load on the engine.
But I have also heard that stuff can loosen up chunks of heavy gunk that will end up in the pan or get lodged in small oil passages.
Seems like the least risky would be to just pull the pan and clean the pump screen, manually clean out the oil pan.
