The "BS" Lounge Off topic posts & general stuff with no category! You talkin' to ME?!?!?! |
Thread Tools | Display Modes |
#31
![]() You'll be pleased to know that the engine-driven rotovator is already 'hotrodded'. It has a big motor on it off a grain auger. The bigger engine was so much heavier that I couldn't lift the blades out of the ground by hand, so I had to mount a hydraulic system on the rotovator. Anyhow, I have finished up the hydraulic system on the tractor and the lawn sweep now. |
#32
Does that little HST machine have a 2 stage hydraulic pump? I have a mini HST tractor that is single stage and it's really different to get used to. The pump isn't fast enough to work with until you speed the tractor motor up considerably. It's still a strain to work a front end loader having to wait and forget trying to make two motion moves with the stick. I have to admit, with everything on it being hydraulic, it's simple to use. And I believe if nothing else, the time lost on slow hydraulics is made up by not having any gear shifts...
#33
Smallfoot, this is a simple pump that needs an open system valve. This means that the pump pumps oil all of the time, where yours maybe only pumps when you ask for work by moving the lever. The valve bodies have an open centre in them, so when the levers are in neutral, the oil flows through the vlave housing. I never thought about how my machine will work at an idle, probably not good. When I'm sweeping clippings or leaves I will have the motor revved up, but lifting the dump gate might not work at an idle.
You've given me something to think about. |
#34
I've been spending my days trying to start the dang little tractor to take it out to the shed for the rest of the winter. First, the new-fangled, automatic choke was not working properly, so I changed it to a manual choke again. Sounds simple, right? Wrong! When you are making new linkage to mount a choke cable, you have to make sure the choke is moving in the right direction. So I spent another day rearranging the linkage so it works now.
Then one of the many safety switches failed so I couldn't let my foot off the clutch or the motor would die. With all of the safety switches you can't get off the seat or let your foot off the clutch/brake or the motor dies and you can't use your test-light to see where the electrical problem really is. I'm rewiring the tractor now in a simpler way, and I'll be much happier, I think. No pictures. |
#35
I hate those stupid seat switches. That’s usually the first thing I bypass. Next is the switch that won’t let you backup with the mower deck running.
#36
My neighbor called me over last summer because her riding lawn mower wouldn't start. I had a feeling it was a safety switch. I said to her look it up online mower wont start. Turns out there was a safety switch near the chute on the deck and it was slightly up. Started right up after pushing the chute down. Kind of frustrating. Jim
#37
I generally bypass anything that ain't related to engine running mode too...
#38
Me too. When my kids were little I taught them to check if it was in neutral before starting and don't get off unless it was shut off. Then again by the time my oldest was 14 she was driving an L8000 that she taught herself how to shift a 5+2 speed. They had common sense. That is hard to teach.
#39
Yessir in todays world, common sense is a super power. I'm glad to be amongst all you super heroes!!!
#40
I agree, Guys, those safety switches are a pain in the a$$ when they are working, and even worse when they're not working. They are all bypassed now, but I haven't started the tractor up yet, from fear of,, of,, failure.
Bookmarks |
Thread Tools | |
Display Modes | |
