50 Dodge Pilot
Looks cool siting in there [cl
Do you have enough clearance to get the valve cover off, if the need ever arises ?
[P[P[P
Got a 6 inch drop from back of trans to rear end. Drive line will be 4 ft long. I'm think'n this is too much. The slant 6 sat lower in the wider donor truck chassis.
Drop doesn't matter, just the final angles you end up with at each end of the driveshaft. You could be alright where it's at, but won't know until all the weight is on the suspension.
Lowered the engine another inch. Was not happy with where it sat so i'm making new mounts...again. I guess I need the practice. The boss wants her garage stall back. I'm slow, but moving forward, need to move quicker.
