Go Back   Rat Rods Rule / Undead Sleds - Hot Rods, Rat Rods, Beaters & Bikes... since 2007! > Questions/Suggestions
Questions/Suggestions Questions or suggestions about the forum... don't be shy!
Old 07-12-2014, 11:42 PM
stovebolt's Avatar
stovebolt stovebolt is offline
Send a message via MSN to stovebolt
Default lake style headers
does anyone remember a tech article on how to build lake style headers using speedways kit? I thought it was in rod and customs but cant find it. it may have been in street rodder. anyone remember?
Old 07-14-2014, 06:19 AM
blacksheep's Avatar
blacksheep blacksheep is offline
Not sure about the Speedway kit. I built mine using a used set of headers. Cut the tubes about 2" from the flange, and welded straight pipes to later cut off to match the angle I needed. I bought a 7' stick of 3" exhaust tubing and a handful, of hose clamps. Measure the circumference of the front pipe, then mark that distance at the end of the 3" . Make two straight lines from those two marks down to the other end of the pipe to form sort of a pie cut. Cut that with your angle grinder. It takes a bit of messaging and hose clamps, but I put that tube in a vise and starting bending. I used hose clamps so that the pipe would not get flat or oval.heres how they turned out.
" Stay rusty my friend "
Located in Ludowici, Ga
Old 07-14-2014, 06:24 AM
blacksheep's Avatar
Sorry, I tried to flip that photo and it didn't work.
Old 07-14-2014, 07:45 AM
Old Iron Old Iron is online now
Old 07-14-2014, 01:51 PM
blacksheep's Avatar
Another.
Old 07-14-2014, 07:29 PM
Yankee Transplant's Avatar
Yankee Transplant Yankee Transplant is offline
He started out with nothing, he still has most of it!
Send a message via Yahoo to Yankee Transplant
the top pipe of the chain link fence is the same size of pipe on a regular chevy header . If I had access to a pipe bender I bet I could make my own ,
Old 07-14-2014, 07:32 PM
Old 07-15-2014, 10:08 PM
sneakysnake's Avatar
sneakysnake sneakysnake is online now
"There’s nothing new in originality"
Don't have the vid but can give some advice, start with the front port and cone, put it where it will lay, then do the last port, then do the two centers.I had to add a little to my last port to clear my '46 firewall.
'46 Build Link
'53 Build Link
"Its a catastrophic success"
