#261
#262
Trailer queens suck! Build it, drive it and be safe! Minterfab.com |
#263
Doing some diagnosing with my tuner today. Pretty sure the oil bypass plunger in the back of the block right by the oil filter shifted and beings that we have a high volume oil pump in there it was probably enough to keep the top end okay but it was not enough to feed the bottom end. I will pull that plug when I get the block all the way out of the car and see what that plunger looks like. I ordered a new one anyway
#264
Did you pressurize the oiling system before the first start?
There are two things in life where penetration is really important .....and one of them is welding. My 48 chevy flatbed http://ratrodsrule.com/forum/showthread.php?t=604 The Roofus Special http://ratrodsrule.com/forum/showthr...ghlight=roofus |
#265
We primed the pump, I also cranked it with no ignition before actually starting. Same as I have done with small blocks. Not sure if that's correct or not. I've never had one do this lol. Also my first LS adventure
#266
Out of curiosity, what brand of oil filter were you using?
1946 GMC Pickup (455 Buick and S10 frame) - Build Thread 1962 Bel Air 1982 S10 1986 Caprice 1928 Model A Roadster Pickup (project) --------------------------------------------------------------- And when I’m gone, you can call me foolish but hopefully not boring. I will have lived. Last edited by 05snopro440; 04-17-2023 at 09:40 PM. |
#267
Wiz filter. That's what I use most of the time. Not sure anymore what is best
#268
Wix, GM, K&N, Napa (Wix) are good. My dad talked to service at the GM dealer after he had a low oil pressure issue after replacing the oil pressure sending unit and the failed afm lifters. The cheaper brand filter he put on had failed, and what he was told was that some of the cheaper filters can fail and cause oil starvation to some parts of the engine. I don't recall which areas though or what they said fails in the filter. He put a GM filter on and it has been perfect since for several thousand kilometers. Wix is among the best so it should be fine.
1946 GMC Pickup (455 Buick and S10 frame) - Build Thread 1962 Bel Air 1982 S10 1986 Caprice 1928 Model A Roadster Pickup (project) --------------------------------------------------------------- And when I’m gone, you can call me foolish but hopefully not boring. I will have lived. |
#269
![]() Quote:
#270
I wouldn't even mess with that rod, replace it.
Bookmarks |
Thread Tools | |
Display Modes | |
