Go Back   Rat Rods Rule / Undead Sleds - Hot Rods, Rat Rods, Beaters & Bikes... since 2007! > Fuel systems Q&A
Fuel systems Q&A Carbs, injection, tanks, lines, pumps, everything fuel system related!
Old 03-30-2016, 09:45 PM
52 fordman's Avatar
52 fordman 52 fordman is offline
Default Compression fitting
Okay I have 2- five foot long steal brake lines with out fittings on the ends. I was wondering if a compression fitting will be okay to put the 2 parts together? I am using a Holley electric 12 volt pump at the gas tank set for a carb ( so no high pressure ) Going to use P clips with rubber grommets along the frame to hold it in place.
Tell me your thoughts and suggestions. all the line and fitting are free! Even the P clips are free.
Thank you
52 fordman
Old 03-30-2016, 10:11 PM
I've done it.
Old 03-30-2016, 11:01 PM
It'll work just fine.
Old 03-30-2016, 11:26 PM
sneakysnake's Avatar
sneakysnake sneakysnake is offline
"Thereís nothing new in originality"
Works fine on fuel line, just don't try it on the brake lines.
'46 Build Link
'53 Build Link
"Its a catastrophic success"
Old 04-01-2016, 07:39 PM
sgtpontiac's Avatar
sgtpontiac sgtpontiac is offline
Older, Wiser and Still Buildin'
Default Yes sir....
I agree...will work fine for that use...
My 96 GMC Rat Buildbuildthread
Old 04-04-2016, 10:49 AM
05snopro440's Avatar
05snopro440 05snopro440 is offline
What diameter is the tubing? Brake line might be a little small for fuel?
My 455 Buick powered '46 GMC Build Thread
My '46 GMC on Photobucket
When you don't know what you're doing, it's best to do it quickly.
And when Iím gone, you can call me foolish but hopefully not boring. I will have lived.
The more I learn about women, the more I like my car.
Old 04-04-2016, 11:51 AM
Neto Neto is offline
I'm not arguing, as I think you are right, but I bought an S-10 some years back, and it burst a brake line. When I got under it to see what I needed to do, I saw that it had been patched in that section already, using compression fittings. I told the guy at the parts store about it, and he said, Oh yeah, you can do that just fine. So since I didn't want to replace the entire line all the way from the front to rear, I put it back the same way. It was like that till I sold it some years later. (I don't remember what parts store it was, but it was one of the big chain auto parts stores.)
Old 04-04-2016, 04:36 PM
It works just fine on brake lines, as long as you use the compression fitting properly there is no concern.
You would need to make sure the one you're using is meant for brake lines, like this one: http://www.autozone.com/fittings-and...?checkfit=true
Old 04-04-2016, 04:48 PM
That's what I had, but later I needed to do a brake line patch on another part of the same vehicle, and since that would be the easiest way to do it, I went to AutoZone in our closest town. But the guy there wouldn't sell me any compression fittings, and said that it was not legal. So now I don't know what to think. (I ended up having to replace nearly all of the lines in the front.)
Old 04-05-2016, 09:13 AM
I've had several vehicles that had lines repaired in this way, and no reliability issues. It's brake fluid, not rocket fuel.
