Go Back   Rat Rods Rule / Undead Sleds - Hot Rods, Rat Rods, Beaters & Bikes... since 2007! > Please Introduce Yourself!
Please Introduce Yourself! Let us know a little about yourself, what you're up to & how you found us? We like to know who we're talking to!
Old 08-20-2017, 01:28 PM
Welcome to the site
Check out my link to the 35 Dodge
Old 08-20-2017, 11:58 PM
eyesore's Avatar
eyesore eyesore is offline
Welcome to the forum!
iSore
Old 08-21-2017, 03:11 PM
Dirtroad restoration Dirtroad restoration is offline
Default vw ball joint frt beam
Has any one used a vw frt beam on there rods and have pics on how to attach it my thought was to Mt it to the inside of the shock towers not much weight is going to be on them since o
I'm running a ford 4 cyl 2.3
also the kick up on the rear of a zeed frame I've seen everything for 10 in at 45 degrees to 16 in on 60 degree
I've tryed to look at a members pic but they don't come up his name is Tusk would like to see some ideas and or pics
Old 08-21-2017, 04:44 PM
kenny c kenny c is offline
Welcome o the site.It may be best to lay out what you have and build from there. When I built my frame I mocked it up out of wood. I used 2x4s with plywood plates on either side of the 2x4s
Tetanus Tornado 49 F6
Old 08-21-2017, 05:19 PM
Blue Eyed Devil's Avatar
Devil's Advocate
No such thing as "plans" for a custom build like that. Gonna have to put in the work...
Old 08-21-2017, 07:25 PM
Click on my signature where it says Tetanus Tornado and you can see my mock up wooden frame in the pics in the pics in the images in the build thread.
Old 08-22-2017, 03:42 PM
Thanks Kenny
your kick up on the rear z is it around 16 in and what degree 60 or 22.5
also the frt z I've layed mine out off a set of plans but my rear is only 10 in I don't think that's enough
thanks for the help rick
Old 08-22-2017, 08:51 PM
It's been so long since I did it I can't remember. I think it was 45 degrees. There are pics of it in steel in the thread. I built it to fit the coil overs. I should have mounted the shocks lower on the rear axle so that the rear frame rails didn't have to be as high. I would have ended up with more depth in the bed.
