Wood is good.
I like finding little things the factory done that wasn't right :D
It gives ya something else to talk about when the project is done and you tell the story of the restore :cool:
[cl[P[P[P
A pleasure to follow along
Much respect for the time, thought, and work involved to bring this boat back. Reminds me of watching dad build wood airplane wings decades ago.
[cl
Man, that's a lot of work!!![cl
[cl[P[P[P
[cl
Thanks Gang.:D
It seems that we all like to think about how well built things used to be compared to today but in reality these boats, just like cars, were a production item. The people that built them were not boat wrights any more then the people that built cars and trucks were Mechanics.
Just everyday people trying to make a living.....
Chris Smth, the founder of CC was known to spend his time down in the boiler room searching thru the "Scraps" of mahogany that the factory burned to fuel their boilers. He would pick out the wood that he thought could still be used even though the guys on the shop floor thought it was scrap.......:D
Thanks Gang.:D
Chris must have been a student of Henry Ford. :D
Still plodding forward.
Weather is still crap here but got some shop time in this morning.
I removed the old decayed Lower transom bow.(Remember the boat is upside down) :)
I will use this old piece as a guide to make a form to laminate together a new one.
Lots of screws and 2 Loooong bolts.[ddd
There is still some debate as to the best way to make this piece. I talked to 3 of my local boat restorer friends and each of them does it different. One laminates. One steam bends and one gets a piece of wood big enough to cut it out. Curve and all.
Given my limitations I will be laminating.
And that one pic shows the location of the nuts that have to be removed.
Thanks for visiting....
Woke up to this nonsense....
Cut out a new backer board to replace one that I was less then happy with and filling old screw holes. No hurry as it looks like we won't see any open water around here for a while.:eek:
Let it snow......
Yes, we're expecting up to a foot here today and tomorrow.
You must have a decent band saw to do all that cutting. Do you have to use a waterproof glue when filling the screw holes?
Super nice craftsmanship. You must be experienced.
About 10" of fresh snow here today bob and it's still coming down.:eek:
Yes I use a waterproof glue. The chances of hitting the same hole with new screws is slim but the hardwood tooth pics will work well to hold them if it does happen.
Thanks for the compliment.:) I have done about 3 CC's and helped others on a few more and a couple of other brands as well.. First time doing this much frame replacement though.
I have a small(14") craftsman band saw that is really being pushed to it's limits at times. Mahogany is hard so it is slow going.
When I want to feel humbled I go visit one of the real restoration pros that have shops near by.
They tolerate my visits be cause I bring then homemade cookies.:D
Thanks for stopping by....
One of the many things that I admire about the people on this site...
Is the desire to help others to learn.
We are not afraid to show our mistakes and ask questions. We all check our egos at the door in an effort to learn and become better builders [cl
A few posts back I talked about replacing a frame backer board that I wasn't satisfied with.
Today I was able to reuse that Backer board to replace one that I cracked when I leaned on the free standing frame end 2 days ago.
A little band saw work and some trimming. Better then before.:)
Just another reason why I never throw out anything until the build is done.
This weekends Progress.
I scarfed a new piece onto the one topside frames that had a rotted end. I then cut a "sister" piece that will be bedded with 3m5200 and thru bolted. This will give the frame maximum strength.
I also cut a sister for one of the other topside frames. It's not rotted but has had a lot of screws put into it. I will dowel all the screw holes and then this sister will be bedded in 5200 as well. Then a couple of thru bolts. Good and strong.
Finally able to make the 50 mile round trip to pick up the wood that was being held for me.
These planks are all 16' long with the 2 wide ones being 18"'s wide.:eek: Awkward to load and unload to say the least....
The narrow 2 will be ripped and used for the laminated transom bow. The wide ones will be ripped to specs and used primarily for the actual bottom planks as a couple of those need to have a 10" wide blank to allow for curve.
About ready to start parking my car outside so I have some much needed room in the shop.
That's it for now.....
Now that the weather is being more reasonable it's time to laminate the new lower transom bow.
I planed down a couple of the 16" planks and then cut to length.
Laid down a layer of packing tape over the bench top so that nothing gets glued to it by mistake.:eek:
Cut backer blocks and then these will be bolted to the bench top.
Need to get some longer clamps as well as lag bolts for the blocks.
That's tomorrows trip into town.
