So should I cut the the tubes to have it centered or can I run it the way it sits? Now I know obviously it has an offset but with a shorter driveline now it's it going to be to much?
I ran my off centered(stock) on my A sedan, and I see plenty of others the same way. Just makes the driveshaft at a angle. Can post some pics if need be. Just make sure your driveshaft tunnel is wide enough
