Old 03-09-2009, 02:03 PM
My time is very brief and I only have a minute here but I've got an issue to deal with. Everything was great and I developed a problem suddenly. Don't know if I'll get it worked out in time for the show or not. I'll explain later when I have some time to type. I did drive it though and here's a photo I snapped while it was outside. I'll come back on later and explain the problem. It'll be after midnight when I get home from work.
Old 03-09-2009, 02:16 PM
tiny1's Avatar
tiny1 tiny1 is offline
Callin' him Tiny is like callin' Dirty Harry a beat cop!
I hope its nothing too serious. I have some buddy from around here i told them to look you up at billit proof
"When you got the money you don't have the time. When you have the time, you ain't got the money"
My Build 49 chevy
First Build 49 ford
My Hub Garage
Old 03-09-2009, 05:18 PM
DougnDog's Avatar
DougnDog DougnDog is offline
Hope it works out for you. very nice rod Doug
Old 03-09-2009, 11:05 PM
Thanks again fellas. Here is the issue. The car was running flawlessly and there was no kind of smoke at all from the exhaust. The morning I started it to go out for a test drive it started running bad and huffing black smoke from the exhaust. It apparently suddenly developed an over rich condition that was bad enough to foul the plugs in a matter of minutes. Hmmmmm. I changed the pressure regulator and threw a new set of plugs in. Same problem. I ran out of time before I could really get into diagnosing the problem. I'm working in the afternoon tomorrow so I'm going to the shop in the morning and pull the hood and air cleaners off and take a look in the carbs while it's running.
The intake manifold that I have is basically designed so that one carb feeds two cylinders each and all eight plugs were equally fouled, so I doubt that all the carbs went south at once. I think that something may have went bad in the ignition or I have too much back pressure in the baffles that I installed in the pipes. I think it's either one of those or too much fuel pressure to all four carbs. Maybe a combination. I'll know more tomorrow and will report back in.
Old 03-10-2009, 12:49 PM
UPDATE! UPDATE! UPDATE! I'm a happy camper today. The problem turned out to be a failure in the ignition circuit. My friend Adam came over and did some rewiring this morning and the car is running crisp and clean again. It sounds really healthy and strong.
It appears tthat I'm clear for take off
Old 03-10-2009, 12:51 PM
Tell em not to be shy if they see me. Make sure they say hi.
Old 03-10-2009, 12:54 PM
Good news. I like a happy ending.
Old 03-10-2009, 12:57 PM
moronthethrottle's Avatar
moronthethrottle moronthethrottle is offline
Cross Member
Permission for flyby granted.
Glad to hear everything turned out OK!
Rusty reflection of the American Dream.
"Not Rod"
Old 03-10-2009, 01:24 PM
I chewed off all my fingernails there for a time. Glad it turned out to be an easy fix.
Old 03-10-2009, 04:20 PM
tiny1's Avatar
Will do Here is a couple pics of there rides. The little truck has a hemi also he just put a tunnel ram with two four's a couple weeks ago. I'm going to send them some pics of your ride too
My Build 49 chevy
First Build 49 ford
My Hub Garage
