Old 01-26-2009, 12:06 AM
BruceR&C's Avatar
BruceR&C BruceR&C is offline
Cleverly disguised as a responsible adult!
Even the small boring things are exciting on this rod. Like the billet to cast conversion & I'm really digging the column cover. Can't wait to see what you have up your sleeve next. (excluding an arm )
Driving Yesterdays Rides-----Today !
'47 Plymouth Coupe - mine
'47 Chevy PU - wife's wiring
Aerodynamics are for those that can not build engines. - Enzo Ferrari
Old 01-31-2009, 08:55 PM
I'm running out of things to take photos of that would look like something. Mostly boring details like mounting the electric fuel pump, installing the fan, blah blah blah. Here's one thing though that might be a tip for others. I wanted to use the factory oil filter in the factory location instead of a remote deal. I found out that wasn't a good idea because of a modifaction I made to the oil system (bypass plug). So I got a Hotheads adapter for use with a spin on filter and got a K&N filter because they have a nut welded on top that looks sort of like the factory cartridge canister. I smoothed and sandblasted the adapter and painted the K&N filter black. From a distance it sort of mimics the factory setup.
I should have the intake bolted down for good and the fuel system worked out and routed tomorrow. I need to make some modifications to the road draft tube also so that it will fit.
BEFORE:
AFTER:
BEFORE AND AFTER:
INSTALLED:
Old 01-31-2009, 09:02 PM
35Mastr's Avatar
35Mastr 35Mastr is offline
Mastr Blastr
That is nicely done.That is going to be a really cool mill when you get done.
1929 Pontiac
George
I wish I could remember everything that I have already forgotten.......
Old 02-01-2009, 02:22 AM
donsrods's Avatar
donsrods donsrods is offline
Looks like you are getting all the clearance issues worked out pretty well, like the drivers side exhaust manifold. Man, that is tight !! Looking like you are getting down to the short strokes though. I especially like the steering column cover.
Old 02-01-2009, 08:21 PM
Thanks again fellas.
I bolted the intake down for good. I had to shorten some bolts first so it took a little longer than expected (as usual). I got most of the fuel system completed but I need a couple of things to finish it off. The carb linkage is done also but I still have to work on the throttle linkage.
Note the hose clamps. Ever seen em?
For those interested, you make those hose clamps yourself utilizing the below tool and safety wire. Fun
Old 02-02-2009, 12:45 AM
I need to take 2 trips; one to Florida to see your coupe and the Donrods family stable and a one trip to Texas to ride in a panel truck and a Chevelle.
Wonderful work on the details, Gas.
Old 02-02-2009, 07:14 AM
Default Really!!!
Bob,
REALLY... we need a carvan to Florida to ride in Don & Gastrick's cars!!!
Awesome work as usual Gastrick!
Old 02-02-2009, 08:02 AM
Amazing as usual.
Old 02-02-2009, 10:36 AM
35Mastr's Avatar
Mastr Blastr
Excellent work.The clamps add that old race car feel to it.
1929 Pontiac
George
Old 02-02-2009, 11:44 AM
Originally Posted by 35Mastr View Post
Excellent work.The clamps add that old race car feal to it.
Or old airplane feel. Gastrick, you are a master of details, exactly the right amount in exactly the right spot. Rock on.
