Go Back   Undead Sleds / Rat Rods Rule - Hot Rods, Rat Rods, Sleepers, Beaters & Bikes... since 2007! > Welding/Metalworking... Talk & Q&A
Welding/Metalworking... Talk & Q&A Get your torch, braze, hammer, tig or mig on here!
Old 04-11-2013, 10:26 PM
GJunktionMike's Avatar
GJunktionMike GJunktionMike is offline
Something's wrong with that boy!
Default Well one side will be easy
First side did not go to well, I was trying to keep the factory seam. Did some cutting and just could not get things to line up. So I'm just going to weld everything and made it look like one piece.
Think I'm strange, you should meet the person that occupies my mind
Old 04-12-2013, 05:32 AM
Great execution on the sunroof plan! It turned out great!
Old 04-12-2013, 09:25 PM
gold03's Avatar
gold03 gold03 is offline
He lives in an "Altered State"!
Hey Nice work. I haven't looked in here for a while. Are you paying the bills doing this now?
Gold03
Old 04-12-2013, 10:21 PM
Thanks guys. yep Gold it pays a couple now. Speaking of that, one more kit truck. This is the 38 I did awhile back, frame time.
Old 04-14-2013, 06:48 AM
gold03's Avatar
"yep Gold it pays a couple now."
That is so cool! it's kinda my dream job, but will have to wait till I retire. I need to keep practicing.
Do you go on any metal shapers forums?
Gold03
Old 04-14-2013, 02:08 PM
"Do you go on any metal shapers forums?"
No not really. Every once in a while I will Google something and check things out. More so stuff about working with a English wheel because I have no clue about working with one, and I often think about getting one of the HF ones just to mess around on.
Old 04-14-2013, 10:14 PM
gold03's Avatar
That's what I did. Bought a cheep Princess Auto English wheel. So far I have spent more time working on the machine than using the tool.
The rollers are OK, but it was real flexible. Added on some more steel tubing. Rebuilt and simplified the adjuster. It works better now.
With your welder you can build one better than you can buy at HF. With some steel slugs, a drill press and side grinder you can make the rollers. Look for some heavy steel plate to build a frame.
Have a look at the Shrinker stretchers.
Gold03
Old 04-16-2013, 02:46 PM
Talking I may be a little low
Here is the plan. This will get bagged so the idea is to set everything off the bump stops so if a bag does blow the truck will stop a 1 1/2" off the ground. With the bags all the way up should ride at 7 1/2" or so off the ground and should have a nice 4" cruising clearance. Of course there is the front bags down and backs up for the rodder look. Even with the tires that are on there now there is still a inch of clearance above the tire.
Old 04-18-2013, 03:59 PM
S-10 frame all trimmed up, made my plywood jig-o-matic and the frame started.
Got in all squared up leveled and some welding. Switched over to the other welder for the frame, that .35 flux core melts thing together in a hurry.
Old 04-18-2013, 04:30 PM
Dirtyrat's Avatar
Dirtyrat Dirtyrat is offline
Got Fins?
Not be be a downer, but you might want to air that tire down too no?
That would be your scrub area with a tire down, but I guess having both go at the same time would be pretty unlikely
Rich - AKA DirtyRat
'12 VW Jetta TDI DSG
Build: '49 Ford F1 + '57 Pontiac, Liquid Propane Injected
1st start up on propane
1st real drive
