Old 05-17-2022, 05:44 PM
Torchie's Avatar
Torchie Torchie is offline
Great save, Mac.
Old 05-17-2022, 09:47 PM
Old Stuff's Avatar
Old Stuff Old Stuff is offline
Great save indeed. I will remember that little treasure that I've never seen before. Are they hard to come by?
Charlie
My '30 Chevy truck build: https://ratrodsrule.com/forum/showthread.php?t=38957
"He is no fool who gives up what he cannot keep to gain that which he can not loose."Jim Elliot
Old 05-17-2022, 09:52 PM
MercuryMac's Avatar
MercuryMac MercuryMac is offline
Builder Junky!
After tightening the last bolts, checking the fluid levels, filling the transmission and boosting the battery a wee bit, I backed this project out of the shop. I've been looking forward to this moment for quite a while.
Tomorrow, I'll test-drive it and bring in the next project.
Old 05-18-2022, 04:14 AM
DozerII's Avatar
DozerII DozerII is offline
Cool, has been a bit a bit of a battle.
Glen
My 29 Essex Build http://ratrodsrule.com/forum/showthread.php?t=34026
Don't give up, it's far too much fun once you can drive it.
Old 05-18-2022, 12:02 PM
MercuryMac's Avatar
Builder Junky!
Thank you, Guys.
Old Stuff, those corner drives are rare, or I haven't seen one before, so when I saw two for sale at a recent swap-meet I grabbed them. When scrounging around on the internet I found that a taxi company still makes and sells those little speedometer cable transmissions to change the speed, so I suppose they might sell those corner-drives too.
Old 05-19-2022, 11:59 AM
MercuryMac's Avatar
Builder Junky!
Anyhow, I took the '36 out for a test-drive yesterday and ----- it failed miserably. The speedo needle lay helplessly dead at the bottom of the guage through the whole trip.
I noticed that the old fuel pump was leaking gas, also. I have an electric pump by the gas tank but I left the old pump plumbed into the system [with one valve removed] to look authentic. It looks like some replumbing will work. Well there goes my [fake] authenticity.
I'm going to A&W tonight anyhow.
Old 05-20-2022, 07:40 AM
The corner drive didn't cause the cable to have a reversed rotation did it?
Old 05-20-2022, 11:15 AM
Bamamav's Avatar
Bamamav Bamamav is offline
You wouldn't by chance have the wrong gear would you Mac? There is two different gear designs, one for the right side of the transmission and one for the left. Difference is the way the teeth slope. I think some top loaders take the right hand gear, C4 and AOD take the left one. Not sure on the T5, but I think it's the left gear.
Old 05-20-2022, 12:17 PM
MercuryMac's Avatar
Builder Junky!
OI and Bama, you both have good suggestions to add to my sleuthing. So far I haven't worried about it enough and haven't looked at anything. Bama, the driven gear comes out of the left-hand side of the extension housing on this T-5, if that's what you mean about right and left.
Old 05-20-2022, 09:40 PM
Bamamav's Avatar
Since it's on the left, it should be the same gear as a C4 IIRC.
I ran into having the wrong gear once. Don't know where it came from, but I was trying to use a right side gear on the left side. It went in the hole, but first trip it stripped all the plastic teeth off.
