Go Back   Undead Sleds / Rat Rods Rule - Hot Rods, Rat Rods, Sleepers, Beaters & Bikes... since 2007! > Electrical... Talk & Q&A!
Electrical... Talk & Q&A! Electrical Q&A.. The shocking truth, tips, tricks & more!
Old 01-23-2019, 09:52 AM
animal's Avatar
animal animal is offline
I'm doing this as a favor for an elderly man who is limited on funds but wants his car to work. I honestly don't believe there is anything wrong with the switch, and the time I spent was due to my own ignorance about electrical theory. I don't like it, but the truth of the matter is that I can route and connect wiring in a perfectly acceptable fashion, but I am, as I have stated a few times, not an electrician. I am woefully short of experience and knowledge about much of what makes some of these components do what they do. Obviously, I could never do this as a money-making venture. I have the time and energy to do what the owner can't, and want to help him out. I'm sure it will be much better when I'm done than it would have been otherwise.
Thankfully, I do believe help is on the way. Josh at AAW asked me another question via email this morning, and says he'll send me a diagram showing the hookup to the harness.
HEY READERS!! My action novels are available as trade paperbacks as well as ebooks. Check 'em out at http://larryanimalgarner.com All proceeds go to car parts!
Old 01-23-2019, 11:15 AM
animal's Avatar
Josh at AAW stepped up and supplied the info to allow me to wire the GM-style plug to the Signal Stat turn signal switch, allowing me to just plug it into the AAW harness. I wish I could have gotten this info two days ago, but am glad to finally have someone who knows what he's talking about willing to help out an old guy without an electrical engineering background.
This is what he emailed me...
"I've attached a sheet pertaining to Signal Stat that our company uses. Since you are using the Dash Indicators, the BLUE wire will remain UNUSED.
To break it down for you:
Sig-Stat GREEN goes to AAW Light Blue (Left Front)
Sig-Stat RED goes to AAW Dark Blue (Right Front)
Sig-Stat YELLOW goes to AAW Purple. (Flasher Feed)
Sig-Stat GREY goes to AAW Yellow. (Left Rear)
Sig-Stat BLACK goes to AAW Dark Green (Right Rear)
Sig-Stat Black w/ GREY TRACE goes to AAW White (Brake Feed)"
Upon asking whether the red/green wire is also unused, Josh said
" Yes, that is correct. That would be if you were running single filament bulbs in the front, and needed to supply power to them for your park lamps. Since the park lamp circuit is already installed in the new AAW harness, this wire will remain unused. "
It's refreshing to get customer support like this. Now I can wire this up without any more fumbling around in the dark.
Old 01-23-2019, 12:07 PM
Thanks for posting the info. I put it my goto files
