Builds! Post your project here... show us what you're up to! Please Note: This section is for "Builds" ONLY! |
Thread Tools | Display Modes |
#191
![]() Quote:
![]() In this case I used the 5200 as a sealer. It takes 7 days for a full cure. I sped up the process by sprizting it with water as it is moisture cured. Had some help this morning so you have to feed the troops. Yes these do have raisins in them. ![]() ![]() We concentrated on the Cadillac hood again. Did some hinge adjustment and Put the springs back on. Same results. ![]() ![]() We noticed that it looks like the hinges may be bent or twisted. The last 2 pics show the hinges. The PS is bent outboard of the car. Hard to see but the DS is pulled inwards as well. The hood rear is off center for sure. May be time to get the porta - power out. ![]() Tomorrow I will concentrate on getting the DS rocker skin on. Then time for some por 15 on the new floor pieces. That's it for now. Keep on keeping on.... Torchie |
#192
MMMM! Make me hungry!
![]() ![]() ![]() ![]() Looks kinda like the hood has been shoved sideways at some time, bending both hinges. |
#193
![]() Quote:
The gap between the hinge and the cowl on the DS is much closer together then the PS. Plus the distance from the hood center to the DS is shorter then the same points on the PS. Its about a half inch, or more different. Its going to take some fussing with. More then one Caddy owner just forgoes the springs and uses a hood prop. The mystery deepens..... And yes Bama. Thise cinnamon rolls were delicious.😎❤️ Torchie |
#194
Getting closer on the DS.
I put a bit of reinforced fiberglass short strand filler on the repaired dog leg. Gave it all a good coat of Chassis saver. ![]() After PT tomorrow I will put on the outer rocker skin. If I still have the strength. ![]() ![]() Kind of looks like a floor now. ![]() ![]() ![]() Torchie |
#195
Nice work
Be Safe ![]() and Be Creative ![]() |
#196
Lookin good!
Trailer queens suck! Build it, drive it and be safe! Minterfab.com |
#197
Thanks gang!!
Thanks Low budget. It looks like a floor again. Considering where it was when i started i am satisfied with it. We are formulating a plan to straighten the hinges while still on the car. I will have to wait until i have some help though. I didn't get to the rocker skins today. First time back to physical therapy and it kicked my butt. I did pick up the elevator bolts i need to secure the square tubing under the Drivers door sill. Hopefully tomorrow. Torchie |
#198
Nice job
#199
Little steps
#200
Getting crazy around here.
Lots of tourists in my area for the 4th. Time to flood the moat and pull up the drawbridge. ![]() ![]() ![]() This evenings progress....... Trim up a few of the elevator bolts. These have a small ledge that they go through to the square tubing reinforcement. Then the rocker skin goes on over these. Which is why I needed the flat head elevator bolts. Of course I needed to be down on the floor for all of this. ![]() A bit of trimming and fitting needed on the rocker skin. Then I can weld it in. That's for tomorrow. ![]() ![]() ![]() ![]() Almost looks like a car again. ![]() ![]() Keep on keeping on.... Torchie |
Bookmarks |
Thread Tools | |
Display Modes | |
