What are you running?
32Bowtie_Rat
May 24, 2013
66
Hi everyone! [dr
I thought I would start what could be a fun thread to see what's under the hood in your rat.
What engine?
What did it originally come out of?
What cam shaft are you using?
Intake/exhaust duration at .050" lift?
LSA?
Do you prefer or smooth or rough idle?
Have pictures to share?
Anything else you want to add about it or what you've done to it please share!
I'm running a 350 chevy from a '69 Pontiac 2+2.
The cam is from Summit Racing & the model is from their street & strip line.
Intake/exhaust duration is 218
LSA is 110
I love the sound of a loopy, rough idle but not too radical as I need to keep the fillings in my teeth. I've rebuilt the entire engine myself & replaced all internal parts with new parts from summit racing but in stock specs. Lots of power under the hood but maybe next time I'll step a little outside of the box.
Enjoy!! [;)
In my 27 I have a 90 Mustang 5.0 that is running a Scat 331 stroker kit. Balanced, 30 over , Edelbrock Performer RPM aluminum heads, Ford Racing X 303 roller cam, Harlan Sharp roller rockers, and two fours on an Offy intake. Cam is very lumpy, comes in at about 2500 and goes right to 8000 if I forget to shift at 7000. :eek:
My rpu has a 394 Olds that is 30 over with a mild Crane hydraulic cam and three Rochester two barrels on an Offy intake. This one should idle pretty smooth and the Olds has enough torque that it should be a good street motor.
My 49 F1/poncho is running a 2010 Ford 5.4 SOHC engine, all stock at the moment, but running liquid injected propane... hopefully to be running soon
S b c
1. 3OISH dodge-small bock chevy & 7OOR4 specs:
ZZ4 350- block is cast iron with 4-bolt main caps-crankshaft is forged steel-cam 208 degree intake / 221 degree exhaust/.474 intake / .510 exhaust- Compression ratio 10:1-Cylinder head Type cast iron 58cc chambers with 1.94 intake & 15O exhaust valves- rocker arm ratio 1.5:1 with aluminum roller rockers-edelbrock carb-torker style dual plane aluminum intake-custom made roadster headers- 385 HP- maximum RPM 5800
7OO R4 built to withstand 5OO HP
2. 1948 dodge truck-small block chevy & 2OOR
1969 3OO HP 327 large journal steel crank-cam Duration 278/288, Lift .420/.442-holley torker style intake & 65O edelbrock carb- 194 cast iron heads
2OOR pretty much stock
Later :cool:
My 40 Pontiac came out with a flathead 6 and now is sporting a 73 455 HO Poncho, 750 HP Holley, vintage Holley Street Dominator with a 700r tranny.
The engines internals are just as it came out of the donor car. Idles like a highway patrol car :cool:
My '42 Chevy has a 455 Olds out of a '76 Olds 98. It is stock other than new timing chain and dual exhaust. I like a fairly smooth idle in my car, kind of a sleeper. I am a huge fan of big blocks, plenty of low end torque.
Ford 302 from a 82 econoline. But it died so I replaced it with a new one from checker with a 3 year unlimited mile.warranty.
Holley 500cfm 2bbl carb
C6 3speed
Anything but...
...a Chevy. :rolleyes:
My Pontiac wagon has a '71 Olds 455 that was rebuilt in the early '80s. It has a long duration 'factory' Olds cam, probably a W-32 "the stick cam," that sounds really radical at idle, but since it has stock rockers, can't have a lot of lift.
This is an old-school hint, by the way. Run more duration, and a tight LDA (overlap) to get the sound, but leave the lift in the stock range, and you won't need to machine the heads for dual valve springs, run longer than stock valves, aftermarket rockers, custom length pushrods, etc.
For the S-10 project, I'm leaning towards the super oddball:
I really wanted to run something old and cool,like a Nailhead or old Cad.ect,but I cant afford it.I running a Chevy 305+turbo 350
HI Everyone
I dont believe in big motors due to fuel consumption and current fuel prices...My rat rod has a 1976 Chevy Nova 250 cu. in. motor hooked to a 4 speed Chevy truck trans....not sure how it is gonna work out but I am hoping it will be OK on mpg's and with the truck being so light...should be able to keep up with traffic too...
MikeC
LS Power in my 54 Belair...
This is the rowdy beast that pushes the Trippermobile down the hiways & byways! 425ci torque monster BB Buick punched out to 431ci, Isky 3/4 cam, 3 Rochester 2G's, aprox 550hp, built TH400 back to Winter's V8 QC. :eek:
'70 model Ford 429 from a '70 Merc Marquis. It came out of the Merc around '84 and went to a '79 F-150. Stayed there until '99, went to a '83 F-150. From there, into a '70 model AMC Rebel. Pulled it and tore it down around 2005. That was the first time it had been into. It sat in pieces a couple years until 2007 when I started building it for what wound up being a VW rat. It's got ported DOVE heads, 10.75:1 KB .030 pistons, Crane 302*/ .610 lift cam, (good radical idle), Edelbrock Victor intake w/ Holley 750 double pump, GM HEI style ignition, home modified BBC Hedman headers, ARP bolts internal, Melling oil pump and Holley elec fuel pump. C-6 auto from the '79 F-150 rebuilt by me. (don't how how that's going to work yet) Currently has a stock 428 convertor cause that's all I could afford.
We are running a nice cheated up 400 SBC out of a short circle track race car. Bought it used so I have no idea what cam it has, but it sounds pretty healthy.
The 6 old stromberg 97s and x-1 intake give it some spice and the high stall converter make it interesting, since it really likes to spin....
Cheers
RustyNCA
My 34 Ford Pick Up is running a SBC, a 262 from a 1975 Monza, a Turbo 350 automatic trans, and a 12 bolt posi 1969 Chevelle rear end.
This is what the engine looked like a couple of months ago when I bought the truck,........and how it looks now.
440 Dodge out of a motor home.
People say it's a low compression engine but it's plenty.
Scary fast in my little ride.
