Transmission, Rear End... Talk & Q&A! Tranny, rear end, drivetrain related stuff... shift it... grind it... pop da clutch! |
Thread Tools | Display Modes |
![]() I'm trying to understand how everything moves, but can't seem to learn the answers from reading build threads. Let's assume that I want to build a 4 link double triangulated, air bag rear axel system. Does it move straight up and down, perpendicular to the frame? Or does it follow a slight arc which is what it must do if the arms are solid, as it moves away from the frame? The rear end of the drive shaft has to follow an arc as it moves up and down, so unless the two are perfectly matched, the radius of each arc is slightly different. In the same way that frame flex induces "bump steer", I'd think that the different radii between the usually longer drive shaft and comparatively shorter pivot arms, would cause the need for an expansion coupling, or at least splines that allow for some telescopic movement in and out between full compression and full expansion of the springs, to make up the difference... otherwise the drive shaft would be too short and sloppy, or too long and bound. So when designing a suspension and drive train system, how do you compensate for the different arcs that are followed, one by the end of the drive train vs. the other, the end of the differential? |
You are right about the driveshaft. That is why it has a slip yoke on the end that goes into the transmission. It lets the driveshaft be longer or shorter as needed.
You are overthinking it. RPM is right, just bolt it on and let the slip joint on the transmission compensate for any arc. Besides, rear ends don't move all that far anyway, unless the rear is bagged, and then you have to allow for a lot more movement in and out on the yoke. But overall, the movement is negligible.
Don |
Watch this video to see how the rear end moves. It will answer 90% of your questions
http://shelf3d.com/Videos/7Z5awRcIkTU ![]() |
There are some general "rules" that are followed when figuring drive train geometry. Trans/motor angle is usually 3 degrees down and pinion angle correspondingly is 3 degrees up. Tail shaft is 3/4" out from the transmission. Triangulated link angles and lengths are fairly standard too - but don't ask me what they are. If you need to use a panhard, the longer the better.
Not so current build - '29 A Rats-N-Rice. Drivers! - '48 Olds '63 F100. Pile of parts - '30 Tudor. "Tough to find rolling papers that size, but it tastes like plastic bags and smells like arrogance!" -Dr. Crankenstein
Here's an easy way to determine the amount of in and out movement of a drive shaft.
The first thing is to get something the length of the control arms you're using. I'll go with a yard stick. Figure #1 is how to set it up Figure #2 is axle arch length. This is the maximum distance the axle will travel in it's up and down motion. Generally between 5" up 5" down (with airbags 10" up inflated and 10" down deflated). ![]() Figure #3 is how to determine the distance the axle will move forward and back with the axle set in the center of it's up and down movement. (static ride height) Measure the distance from point B to point D. This is that amount of forward movement. Note: With a 4 link system, drive shafts do not move away from the tranny. The maximum distance away from the tranny is the starting position, points B ![]() A triangulated 4 link system does not move side to side in it's up and down motion. It will move a very minimal distance in a heavy side load situation is all. Hope this helps ![]() |
Awesome thanks guys. Cool video. It helped me find a few links like this one!! Bit of a problem, because now I really like these cantilevered systems. Since I plan to build my own frame, I'll have to think through these too. This one is just incredible:
https://www.youtube.com/watch?v=ieXHZV-kcuw It seems like these systems force the up and down movement to be more linear and less arcing too, so here a traditional slip yoke will allow for plenty of compensation. Maybe this discussion would have been a better fit under suspension, but I put it here because of the rear end driveshaft interplay. In these more sophisticated scissor style systems you're asking for and getting a lot more from the airbags because of the leveraged forces involved. I'm days from buying a very heavy, hulk of an old car. Obviously there's a flood of vendors selling airbags. I'm only starting to open the pandora's box of understanding them, but I'm sure the load ratings and qualities are all over the map. Do builders typically source a specifically rated bag for each application or are they all in the same general ball park for automotive applications? |
Thanks Old Iron! I had a similar plan in mind for comparing in/out travel. BTW, I took a look at your Pontiac thread. Very similar to the car I am considering. Haven't bought it yet, but it's in great condition compared to the other stuff I've been considering. I'll keep an eye on your progress and will let you know if I go for a Pontiac build.
![]() Quote:
My recommendation, for what it's worth, is to go with something simple. I don't want to be rude, but if you aren't familiar with driveshaft slip yokes, and U-joint angles, you might want to steer clear of three and four link air suspensions all together. You might be okay working with a universal kit. There might even be a kit that is meant for your car. Well, not if it's a '30s Pontiac. For example: http://airbag-depot.com/catalog/avs-...77c8a38dbb791b As far as the bag goes, generally, make sure the load rating is correct for the placement of the bag. One position can multiply the force on the airbag, another could divide the force on the airbag. If you have a 48" link, and you put the airbag in the middle of that link, the force on it will be double what it would be right on top of the axle. So 2000 pounds at the axle puts 4000 pounds on the airbag. Then after that, different bags have different rates, just like springs. Some people actually call them air springs. Generally, a big fat bag will have a higher rate, and will ride stiff. A small, thin bag will have a lower rate, and will be smoother, maybe too smooth, and you could be hitting the bump stops and the travel limiting straps just driving through an intersection. You won't like either one. This is just about everything I know about air bag systems. I do know driveshafts, and angles, but not airbags so much. Surely someone else can spread some more wisdom around here.
░ "The way to get started is to quit talking, and begin doing." -- Walt Disney 42 Chevy build 8literbeater build |
Bookmarks |
Thread Tools | |
Display Modes | |
