Transmission, Rear End... Talk & Q&A! Tranny, rear end, drivetrain related stuff... shift it... grind it... pop da clutch! |
Thread Tools | Display Modes |
![]() It looks like a turbo 350 long shaft and also has the vacuum plug on the passenger side of the transmission body. It also looks to have a plug to a 700R-4 transmission on the driver side I have ![]() Truck had one of those wonderful electronic quad-ra-jets.... Any ideas? ![]()
Be transformed..... Romans 12:2 |
looks like I have stumbled across a 350C
A 350 turbo with a lock-up converter
Yes th-350c with a long output shaft. (12 in) med shaft is 9in. short is 6in.
http://tobbystransmissions.com |
Thanks for the confirmation
Well it looks like a 12" tail, but ck it. The 12's are very rare and not wanted. Good luck. Tobby
needs a lock on the governor too, i know from experience.
Can you educate me on what this means?
in picture #2 there is a domed looking cover. there should be a spring wire that goes in the hole above the cover and in a hole on the bottom side then slips over the cover to snap in the hole in center of the cover to keep it from coming off. i had one come off at a stop sign because it didn't have the lock wire and dumped all the fluid on the spot.
![]() Quote:
They did not use the wire clip on the 350C trans.....
But you better pull the governor to check for a stripped gear and stuck valve.
"The smart guy will outsmart himself. The lucky guy will run out of luck. The money guy will never have the desire. But hard work will take you anywhere you want to go!" Speedy Bill Smith R.I.P. "Imagination is more important than knowledge. Knowledge is limited. Imagination encircles the world." "It sucked itself along, just like a Hoover" Whittle "People throw rocks at things that shine" JBH " Rat Rods Forever" |
Bookmarks |
Thread Tools | |
Display Modes | |
