Builds! Post your project here... show us what you're up to! Please Note: This section is for "Builds" ONLY! |
Thread Tools | Display Modes |
#3171
![]() ![]() I’ve learned lots just watching this build Thanks ![]() ![]()
Be Safe ![]() and Be Creative ![]() |
#3172
Amazing work Torchie. You have really made a masterpiece there.
My '28 Graham Build. http://ratrodsrule.com/forum/showthread.php?t=17465 '48 Thriftmaster Build http://ratrodsrule.com/forum/showthread.php?t=37447 |
#3173
Most definitely an interesting build. I like the process and the outcome.
#3174
![]() Quote:
Learned a lot from my mistakes....think I'll make a few more.... ![]() |
#3175
Thank as always . Gang.😎😎
Things took an interesting turn last night. It seems I did inherit 2- 331 hemi engines. If they are the ones that I remember one of them was rebuilt and never put in anything. Ok. Hemi gurus. How do the engine mount location compare to those on the 318? Also...... Transmission options(automatic) or is it all going to need an adapter. I’ve been researching and haven’t gotten any concrete answers. Thank for any and all responses. Torchie |
#3176
They're the same as the 318's that are on the front corners of the block.
The first pic is the difference from a SBC and the Hemi before I moved the mount forward.
1933 Pontiac 401 GS Nailhead 1935 Dodge pickup Blown Big Block 36 Chevy Master 37 GMC 38 Ford Bobber 1948 GMC 5 window 51 Chevy 5 Window 53 AD Chopped, sectioned and narrowed 53 International Nova 63 LS swap 65 GTO LS swap Last edited by Old Iron; 11-07-2021 at 03:25 PM. |
#3177
Hemis are rare around here and now you have two
![]() ![]() more ![]()
#3178
Thanks OI and soltz.
![]() I won't be getting the engines till spring. Here are some pics of the 318 front mounts. Based on OI's pictures I'd say they are a bit back from where the hemi mounts are. Any thoughts..... Torchie |
#3179
Torchie, I have some information on the bellhousings. Chrysler V-8s had the same rear bolt pattern up until 1962, so even the Poly bells will fit. Lots of pick-ups had New Process 435 transmissions behind Poly's so those will work if you want a standard truck 4sd. If you wanted to mount an NP A833 car 4sd, there is lots of flat area on the back of the bellhousing, but you will have to bore your own holes. I mounted an A833 behind my baby Hemi. [pictures] Bellhousings after '62 probably have the same bolt pattern but the centering studs are in a different place and they are a way easier to install.
#3180
A pair of 331's. Great news Torchie
Bookmarks |
Thread Tools | |
Display Modes | |
