The Z.Z.Rat Build
That suspension is so freakin' trick. I love it! Simple elegance.
Your 39 is sooooo different than mine. They both have yellow parts, though... :)
also been working on the floor of the Boss 429 truck
re shaped the edges of the sub rails
made a new center sub rail to replace the rusted and bent one
still need to do the kick up over the tail shaft in this pic
starting to do some pans, once i get them all mocked up i will pull them back out and add some beads for strength
the customer brought me this tractor hood, he like the gauge pod and center section. and wanted to add it to the tunnel.
tomorrow i will get the front of the tunnel roughed in and fit the gauge pod area
started making the area over the main part of the transmission, started by doing shrinking to get the edge to roll over.
fitting in the truck after some plannishing
then to make the pass side to match
mostly tacked up
here is the driver side all welded, plannished out and hit with the sander
