Old 12-10-2019, 12:22 PM
bruno's Avatar
bruno bruno is offline
Crusty Rusty Old Rat Rodder!
Absolutely nothing.
_______________________________________
The smoker you drink, the player you get.....Joe Walsh
Old 12-10-2019, 02:22 PM
Originally Posted by Dr Crankenstein View Post
I didn't know Porsche made a tractor, until now.
I was thinking I knew that for some reason, but then I realized it was Lamborghini that started as a tractor company and became a car builder. He got ****ed at Ferrari and decided to start his own car company (I think that's how the story starts - ?)
Old 12-11-2019, 12:57 AM
soltz's Avatar
soltz soltz is offline
The Rat Captain
Cool Wildfire $
Originally Posted by smallfoot View Post
In sunny California????
A little goes a long way and my grass likes it
Be Safe
and
Be Creative
Old 12-16-2019, 06:29 AM
kenny c kenny c is offline
Stripped the 2000 Ford Explorer that I bought for the 302 . I'm going to try to sell off as much of it as I can to recoup some money to go toward the 37 pickup build.
Old 12-16-2019, 10:30 AM
Worked on my doors & did chores around the farm I've been neglecting!
Old 12-21-2019, 09:46 PM
smallfoot's Avatar
smallfoot smallfoot is offline
Well, so far I haven't got much done...still building a house with my bud. We're painting walls and ceilings and placing outlets and starting to place fixtures. My next inspection is Pre-power, which in this case will be permanent power because of the way we planned it out. But Thursday morning I woke up to no water at my house. I have a submersible pump down a drilled casing here for my water. I went methodically thru all the tests and determined the problem to be the pump. Everything else tested ok but read trouble down to the pump. OK, ya'll know what I'd do, I'd pull the pump myself...done it before, I can do it again. So I jumped online to Amazon and ordered parts and pieces to do the job and left a few locally obtained pieces until I saw what I had after I got the pump out. Friday, up early to start pulling the pump. Parts will be here Friday night. I'll get them early saturday morning where they get delivered to my daughter's house because delivery trucks can't seem to find my place... . By quitting time I had only moved the pump up about 16 inches... . Last thing I did was sanitize the well with bacterial bleach. Next morning I placed the come along on it and it started coming up easy and I managed to pull it by hand. Cool beans! I got my parts and my buddy Junior stopped by to help with putting it all together and back down the shaft. About dark we had it all back together. New pump, new drop pipe, all new fittings. Before I left to pick up incidentals for the build, I checked everything again to be sure everything else was right.I checked everything right to the end of the circuit driving the pump. 123 volts each leg and good ground to pressure switch, closed switch and read the same power at end of wires to go down shaft. When I fired the pump up, it pumped immediately up to 50 psi where the pressure switch shuts it off. Ok, we have a faucet wide open, the first out of the tank to flush the system as we get sand down here after well work usually taking a good while with everything running to flush the sand. When the pressure got down to 30 psi it should kick back on. The pressure switch operated one time and failed..tried cleaning points to no avail,..sheesh! Back to get parts in the am...
Old 12-22-2019, 12:26 AM
Good luck, smallfoot!
Building things makes me happy... repairing things, not so much.
Old 12-22-2019, 05:57 AM
DozerII's Avatar
DozerII DozerII is offline
Murphy decieded to make a stop in Florida I see. Kick his butt outta there and everything will go smooth.
Glen
My 29 Essex Build http://ratrodsrule.com/forum/showthread.php?t=34026
Don't give up, it's far too much fun once you can drive it.
Old 12-22-2019, 08:02 AM
forbigpicture's Avatar
forbigpicture forbigpicture is offline
Please stand by.......
I'm feelin' ya smalls.....
Learned a lot from my mistakes....think I'll make a few more....
Old 12-22-2019, 08:22 AM
smallfoot's Avatar
Did I mention we're supposed to get 5" of rain today???
