#2181
#2182
Casing top is 12" above the ground. It's never been under water even in the hardest rains.
I don't think it's coming in from the top. Are you saying it might be going down the outside of the casing? The way this sand is acting, I think there's a lot of silt. I poured a bucket full out of the air lift end about noon. There is a bunch of sand that settled but the water, undisturbed, still looks like mud. It's been sitting all afternoon. |
#2183
i was waken up by a big thump about 9:40 this morning. Looked out the front window, and someone was parked in the space between my driveway and the neighbor's. And the new power pole from this summer was broken in half laying across my driveway. Some of the neighbors caught the driver trying to run away from the scene. Drunk as a skunk. So, from around 10:30 to almost 4:00 I got to watch the power company replace the pole and restore power to the block. I got off easy. The mast to my service is a little loose, but my neighbor's was torn clear off the side of their house. And to msake it even more fun, they are out of state visiting family. I called them and let them know what happened. The power company crews were great. I'm warming up again, and fed. Life is good. Happy holidays to the lot of you.
39 Ford PU Build. http://ratrodsrule.com/forum/showthread.php?t=36459 1928 Ford Tudor Build http://ratrodsrule.com/forum/showthread.php?p=538231#post538231 The thing about a '39 Ford pick-up is that that ugly grille kinda' grows on ya' after a while. Not taking anything too seriously. ![]() |
#2184
![]() Quote:
#2185
Glad your heat is back on Skip. I don't like cold.
Street Urchins RRC '30 Ford tudor '42 Chevy pu '23 Ford bucket '27 Ford rdst '88 vette monowoody '25 wood cpe '25 IH rdst pu project '26 Ford bucket project |
#2186
Well......damit! Got the new pump up about 10 ft, stuck again and pulled apart.
OK, down about 20 ft. and brand new $ 500 pump, all the drop pipe and all cable came out, so we assembled 40 ft of 2" galvanized pipe and pounded the dam thing back down intending on pushing it down as deep as we could. Got down to the original pump location and it stuck again, a 9lb. sledge only pushed it another 2 ft(32 ft). It's bottomed on sand. sheesh! Put another brand new pump down at 24 ft. and held it by hand so I could move it and just hooked power to the pump and was intending on seeing if another regular well pump would pull the sand out and quicker. Flipped the switch, pump worked great for about 5 minutes hauling up sand by the buckets and lots of muddy water. I was watching as it ran, ready to shut off and pull if it failed. I could hear the pump running and then the water stopped but still heard the pump. I flipped the disconnect switch and pulled the pump up by hand. When it came out of the casing, I noticed a wobble between the pump and motor. Got it on the ground and pulled the screen around the intake. As soon as I got behind the screen, I could see why it wobbled. I think the sand locked the pump and the torque of the motor twisted the assembly enough to snap the legs holding the pump to the motor. Boys, I did everything possible by me to save the well. Calling the well drillers out to place a new well. ![]() |
#2187
Good grief small
#2188
That really sucks SF
Glen My 29 Essex Build http://ratrodsrule.com/forum/showthread.php?t=34026 Don't give up, it's far too much fun once you can drive it. |
#2189
Yeah, I could build another hotrod for what this will cost....
#2190
The state will now be known as Lorida, because smallfoot used all the effs!
- The distinction between psychological illness and creative thinking is wafer thin - 1937 Chevy Coupe 1938 Chevy Sedan Photo Posting and Resizing |
Bookmarks |
Thread Tools | |
Display Modes | |
