Power Cowl Vent?
Vacuum motor from a hiding headlight system, or the vac motor that was used on the heat riser exhaust valve. GM/chevy even had a pushrod incorporated into the ones they used on the pick ups years ago.
autolok sells power actuators cheap , you won't need a very large one so that will keep the cost down . They have adds in every streetrodder magazine
I was thinking of using a damper acuator from a newer AC unit off a chevy truck or a power lock acuator but I think it will be a to quick and jerky.
headlight motor from a vette, or a firebird (82-02) that would work and used ones are cheap. I think I have some and the relay box to run them if you want them.
Why not put a wiper motor on it then it will open and close all the time. Then put teeth on it and letter eat![ddev
Caddys used to have a power trunk latch that slowly lowered the trunk lid the last little bit. I'm not sure how the mechanism works, but it might be something to look at.
