Old 12-23-2013, 09:48 AM
Default 48 GMC 5 window
This 48 GMC is the pickup I got from John as part of the trade for my 40 Pontiac convertible I was building.
I'm gonna do a restomod. Sorry with this being a 5 window, no chop on this one.
Factory length short bed
Mustang ll, tubular upper and lower control arms, 2" drop spindles coil springs with shocks, disc brakes and 5x4.75 bolt pattern
Chassis Engineering rear leaf kit
Either a 5.3 Vortex or a LS1 depending on which one I come up with first.
Behind it will be a 4l65e tranny and a 3.73 disc brake limited slip 8.8 Ford rearend
Here's where it starts
Cab
Rusted cab corners
Driver side inner and outer
driver side new
Passenger side outer only
Passenger side new
Floorboard out
I'll have the floorboards in today and post up pics this evening
Old 12-23-2013, 10:51 AM
54IrrationalHarvester's Avatar
54IrrationalHarvester 54IrrationalHarvester is offline
Default sweet
Love them 5 windows. You have talent so I can't wait to see this.
I wish I could find cab corners for my R-102. I may just find something close enough to shape and hack them up to fit but they typically are not very cheap.
I assume a strecher wouldnt work to curve them because of the radius on the bottom instead of a sharper corner.
anyone ever make a wood buck and hammer them out?
Real Men build their Dreams
Old 12-23-2013, 02:33 PM
Bamamav's Avatar
Bamamav Bamamav is offline
Love those five windows!
Old 12-23-2013, 06:16 PM
Default Floorboards
I don't know where you could find the 54 IH cab corners. Like you said, might be able to use something else that would be close.
I had a lot of traffic in the shop today but, still was able to get the floorboard in
Old 12-23-2013, 06:23 PM
I-R-POPS's Avatar
I-R-POPS I-R-POPS is online now
''Rusty Mopar Slacker''
Pretty clean old cab. A great jumping off spot
I like being able to see out the rear corners
Old 12-23-2013, 07:22 PM
Texaswino Texaswino is offline
When I lowered the lid of my 48 Thriftmaster 5 window, I made new corner glass by laying 1/4 Lexan I had cut in the correct shape, over the original glass in a kitchen oven on 250 degrees until the Lexan melted and took the shape of the original glass. Looked like original. Sounded different if tapped on.
Old 07-18-2014, 07:43 PM
ratnest ratnest is offline
Default Cab corners
Hey man, you can make them yourself if you got the time. Get a beater bag and hammer with a round nylon head and a piece of sheetmetal cut close to size you need an start beating it. It will look like hell at first, but once you smooth out the bumps on the english wheel you will be glad you did. It is not rocket science. The first one may take 90 minutes, but the second one maybe just an hour. If you weld a pipe handle onto a oxygen bottle cap, you can use that to get started on the beater bag. It takes a lot of muscle, but it is dirt cheap and when you are done you will want to show everybody what you did. Or you could buy corners for another truck and re shape them to fit your truck quicker.
