Hercules
Grill shell looks great.:cool: :cool: :cool:
You will figure out the stud issue.
Some day I will build one from scratch. New metal. All nice and shiny.:eek: :D :D [;) [;) [;)
[P [P [P
p.s. You are fast.:cool:
Got some sheet metal work done, started with easy flat floor pieces, formed the driveshaft tunnel over - a driveshaft :) - took some grunting, 18 ga. is tougher to bend than 20 ga. but easier to weld without burning holes.[;)[;)
Made and installed the cowl skin, the filler pieces below the window frame I made from 1/8" plate and welded the skin on from the underside to it so there is no weld showing below the window frame..
What about brass cap nuts or brass pan heads, polished of course.
I like the brass, but not so keen on a bunch of fasteners on the surface. I may just grind some spots on the backside and weld studs on - not like its a fabulous paint job, a little sanding and a re-spray is not the end of the world, I just hate do-overs....
There will be more brass trim to come though, window frames and such - lots of ideas floating around in my mental toolbox...:rolleyes:
MercuryMac got me thinking about the 'looks too thick' stick for the Ford tranny, so I dug up the old shifter from my 34 Caddy project to graft onto the Ford end. Sometimes its actually worth hanging onto old stuff.
I think that's what I'll do on my A shell, welding studs on the back, except it's quite thin sheet metal so it will be a bit of a challenge.
This is what happens when I'm left unsupervised with a chunk of metal and a bead roller... "The Flying H" :):cool: My bead rollers throat was not deep enough to reach the center, so I had to cut it in half thru the center of the H and weld it back together.
Tires showed up yesterday so I had them mounted - the guys at Kal Tire couldn't understand why I would put the white letters in... it's hard to get old school tires like this in the sizes I wanted so the BFG
Radial TA's are an easy way to go, just can't get blackwalls.
Thinking I might do the brass thing on the Flying H too....[S:rolleyes:
Love the flying H![cl[cl[cl
I did the same thing with my new tires. To get the sizes I wanted, they came in white letters. If it had been a mid 50’s I’d probably turned them out, but I like black walls better on earlier stuff.
