I apologize for my absence, between spurious and fitful supply of parts for my 47-55.1 kits I have spent a large amount of what was supposed to be building time, and therefore personally enjoyable time, hunched over my small cnc table cutting parts for orders. because I am an idiot who loves misery I also insist on iterative design changes at every order, so the lead time for cut parts takes 3x longer because they have to change the nesting and update it instead of just cutting what i ordered last time.
i planned to do 48-52 fords next and even bought a couple 1/2 tons to start with but the incessant cutting and all the rental problems... ugh. i keep getting asked for a 41-46 kit, i have pictures of the two I did in some of my ads. i had some patterns but they sucked and building it as 4 piece parts sucks too, i would rather have a cant-mess-it-up-on-a-bet folding set like the AD stuff. my friend had a 46 and kept it at my storage building as yard art when he took a contract job in florida, good enough to start with anyway.
I did the 3D on the mounts and popped out an improved set to try out the cab. worked wonderfully (the second time, as usual)
he had a 1 ton front clip that was in better shape and so I popped that on for a look too.
everything looking ok, I started on making the running boards fit. but a big problem, no matter how i moved the front clip and cab around the running boards were way below the cab. weird!
then i realized the problem, the one ton front clip had running boards taht were two inches taller than 1/2 ton. look at the vertical section under the door
that meant that the back of the fender dropped two inches lower than a 1/2 ton, even though the wheelarch measured almost the same radius. a quick section was needed. success!
so now the runningboards were sorted, i needed mounts for them and the front clip.
more in next post
more in next post
