Old 05-13-2023, 01:49 AM
lowbudget50's Avatar
lowbudget50 lowbudget50 is offline
Grrrrrrrr!
Trailer queens suck! Build it, drive it and be safe!
Minterfab.com
Old 05-13-2023, 10:07 AM
Been there, done that. Just like you, no fun to do it twice.
Old 05-31-2023, 08:51 AM
Who would have known that GM would have had 2 different lengths of the back flange on the 6.0 crank. We ended up having to turn the mounting flanges on the converter down to make everything fit properly. Engine is back and transmission are back in. Almost ready to fire back up.
Minterfab.com
Old 05-31-2023, 11:46 AM
smallfoot's Avatar
smallfoot smallfoot is offline
Fingers crossed...
Old 06-03-2023, 02:56 AM
I've never had a build I hated so much!!! Got this things all put back together and started. Made it to the end of the driveway and lost oil pressure again!!!!
Minterfab.com
Old 06-03-2023, 06:52 AM
Did you use an oil pickup tube o-ring that you had to use a little force to push it into the oil pump or did it slip right in?
I've had this issue and found out I had used too small of an o-ring out of the gasket kit.
Old 06-03-2023, 02:47 PM
It had 60 lb of oil pressure at 600 RPM idling in the shop. I moved it outside and drove it down the driveway at an idle and it lost oil pressure. I've checked the o-ring on the oil pump multiple times to make sure it's the right one. I bought a new oil pump this morning I really hope it didn't hurt the engine. If it did I don't know what I'm going to do cuz I'm done with this thing
Minterfab.com
Old 06-03-2023, 04:06 PM
dutch dutch is offline
That sucks man... I hope you will find the problem before you have to buy a hemi.
Old 06-03-2023, 05:36 PM
We should have bought a hemi!! Way cooler good sir!!
Minterfab.com
Old 06-03-2023, 09:05 PM
It's alive!! For now!!
Minterfab.com
