#571
#572
After a week of tomorrows I finally got the exhaust finished up.
Too many other irons in the fire. Next up is to convert the in tank fuel pump to one that will supply the TBI with the right pressure and a return line.
POPS '48-'52 WILLYS LONG CAB '52 WILLYS JEEP PICK UP '47 DODGE SHOP TRUCK '48 DODGE PILOT HOUSE RAT ![]() ![]() |
#573
![]() ![]() ![]() ![]() ![]() ![]() ![]() Torchie |
#574
On my 46 both pipes go to the passenger side like yours, the mufflers are standing upright, and then proceed to the back. Full duals, but it makes it real easy to put in an H-pipe. You have a bigger trans and crossmembers and a transfer case, but it looks like you have room to do duals if your heart was set on it.
My 455 Buick powered '46 GMC Build Thread My '46 GMC on Photobucket --------------------------------------------------------------- When you don't know what you're doing, it's best to do it quickly. And when I’m gone, you can call me foolish but hopefully not boring. I will have lived. The more I learn about women, the more I like my car. |
#575
![]() Quote:
#576
Nice work.
#577
#578
I found out the fuel pump for a 2006 Dakota has a 80psi max pressure with a 58psi system pressure which is perfect for the FI Tech TBI. With a slight modification to the mounting flange [cut the locating tab off] I was able to use the plastic threaded tank nut from the 1995 donor tank.
Installed a return line bung fitting and a vent/roller valve fitting in the top of the tank. A second 60 mile round trip to the big city for more 6an fittings and a few minutes in the morning to finish plumbing the lines, install a pressure gauge and I have it made. I'm thinking I might be ready to fire this puppy for the first time by the end of next week!!! ![]() ![]() ![]() ![]()
POPS '48-'52 WILLYS LONG CAB '52 WILLYS JEEP PICK UP '47 DODGE SHOP TRUCK '48 DODGE PILOT HOUSE RAT ![]() ![]() Last edited by I-R-POPS; 09-01-2021 at 11:05 PM. |
#579
First class work POPS, everything looks great.
My '28 Graham Build. http://ratrodsrule.com/forum/showthread.php?t=17465 '48 Thriftmaster Build http://ratrodsrule.com/forum/showthread.php?t=37447 |
#580
Bookmarks |
Thread Tools | |
Display Modes | |
