Builds! Post your project here... show us what you're up to! Please Note: This section is for "Builds" ONLY! |
Thread Tools | Display Modes |
#141
1947 Lincoln Zephyr Coupe 1982 Corvette Collectors Edition If it don't shine, I don't want it on mine!
#142
Thanks Bob. It's my inner simplistic tightwad making an appearance.
![]() ![]() Quote:
One thing I didn't think about was it mashing down over time- appreciate that note. ![]() ![]()
Charlie My '30 Chevy truck build: https://ratrodsrule.com/forum/showthread.php?t=38957 "He is no fool who gives up what he cannot keep to gain that which he can not loose."Jim Elliot |
#143
All the activity on this site is inspiring.....
Starting to put together a connector list for the air line related stuff- rear bags, solenoid, a few gauges, pressure regulator, dump valve, air chuck, air horns, etc. Also made mounts for the tank going under the bed. Just need to weld it up and take some pics. ![]() ![]() ![]() ![]()
#144
Between working and some medical needs seems like I haven’t been here forever- but some things have been happening for sure.
Got the remote jumpers installed. The side view pic is a little deceiving making it look like the clamps would be dangerously close to the spring hanger bracket- but the bracket is set well back in on the frame. The ends of the jumpers are plumb with the bed frame. Also got the air tank and compressor in. Will be adding an additional tank up on the bed that will follow the looks of the truck.
#145
Looks good
Be Safe ![]() and Be Creative ![]() |
#146
Thanks you sir! After a short medical time down I'm hoping to start piddling around on it some more this week!
#147
Air lines. After talking with a few here and doing some research I decided to use DOT rated brass fittings just because it feels and looks right. Sometimes it’s okay for me to spend a little more money on some things…
The brass bulkheads were about 1” too long for both tighter fitting up under the splash apron and on the inside of the cab which will be covered by the kick panel. I shortened all those and then had to re thread the left over bare brass for 1/4 NPT to keep everything same-same. From there, lines will go to the regulator with cool handle (TBD) in the dash area and up to the gauge/back out to the bags. Plastic lines will be hidden from all but climbing under the truck. I like the look of the copper and brass at the cowl area. Will tweak those lines a tad before all is said and done as the bends climb up the side of the cowl. Different. Right for the truck.
#148
that looks slick
#149
Neato!
#150
Thanks guys.
Bookmarks |
Thread Tools | |
Display Modes | |
