Builds! Post your project here... show us what you're up to! Please Note: This section is for "Builds" ONLY! |
Thread Tools | Display Modes |
#641
![]() You guys know if there are any legal specs on headlight heights. spaces between ect? With the proper space I need for travel at front wheels lock to lock I'm at 27.5" road to center & 32" from center to center. I'll be 2" back from the front edge of the grill & 1.5" back from the edge of the frame horns. It's really where I have to be to get 2.5" of travel at wheel lock when the tire is under the bucket. I'm not sure why I'm worried about legal headlights.... noting else will be legal LOL |
#642
This is my thoughts on headlight /shock brackets. I have these bolt on shock brackets from Pete & Jakes and thought I' bend up some solid 1.250 solid bar stock and saddle it with the bracket. Not sure if these pictures will make any sense.
I'm gona bend off the angle to straight up and the forward.... |
#643
I like the set up, Coup. The shock mounts are down close to the base of the bracket, so the the shock doesn't have much leverage on the bracket. This is good because the constant raring up and down of the shock will eventually flex the side of the frame enough times to rip a chunk right out of the frame, if the shock has a lot of leverage up high on the headlight bracket.
Your doing fine. |
#644
You be fine on the spacing and height of the headlights.
#645
I agree it looks really good!!!
Trailer queens suck! Build it, drive it and be safe! Minterfab.com |
#646
Dat's some shiney chrome OI.... looks about the same height. Thanks
Thanks lowbudget Well this might be my last productive post for a bit.....shoulder replacement surgery on Thursday. Left shoulder and I'm righty so this one may be easier and if I can't work one armed I'll have to do some Imagineering as you gents call it. Made a jig to bent some 90's in some 1 1/4" solid bar stock for the headlight / shock mounts. Have to bend a 25 degree to bring them up where they need to be. Some pictures of the bend. |
#647
Good looking jig for bending!
![]() Take it easy and heal well ![]()
Be Safe ![]() and Be Creative ![]() |
#648
Thanks Soltz.
They tell me surgery went great. Same day on last Thursday. Friday morning I wake up and can't breathe well. I'm like here we go again with the blood clots, back to the hospital I go for a CT. Thank good no blood clots in my lungs. ![]() They told me I had pneumonia and treated me with IV Antibiotics for 3 days, then they tell me I didn't have pneumonia and have a collapsed lower lung lobe, gee wiz. Home now and dealing with typical shoulder surgery pain. EKG showed some changes so have to talk to cardiologist. Back to imagineering..the bottom of my headlight buckets have a stud & a flat. I believe I'll need a set of concave / convex discs so I can tilt / adjust the buckets. Can I buy these or do I have to machine them? Also has anyone converted buckets from bulb & reflector to LED? If so can you share the source? Thanks Guys |
#649
Good Evening Gents,
Hope everyone is doing well. Shoulder is out of the sling and I'm 2 sessions in to PT. Little rough moving the shoulder the first time. PT is not going to be easy....but I can do it! Spent a little time out in the garage today making the second angle bend on the 2nd headlight / shock bracket. Felt good to be out there and hold that torch in my hand....good arm that is. After heating the bend was easy since I had about 3' of excess material plus a piece of pipe for leverage. Maybe tomorrow I'll cut everything to size. |
#650
"PT is not going to be easy....but I can do it!"(quote couper)
In all you do, that attitude is key! Heal well buddy! |
Bookmarks |
Thread Tools | |
Display Modes | |
