Old 07-23-2020, 01:17 PM
Skip's Avatar
Skip Skip is offline
Can I have your old useless worn out unsafe belts? I promise not to go racing in my next project.
39 Ford PU Build. http://ratrodsrule.com/forum/showthread.php?t=36459
1928 Ford Tudor Build http://ratrodsrule.com/forum/showthread.php?p=538231#post538231
The thing about a '39 Ford pick-up is that that ugly grille kinda' grows on ya' after a while.
Not taking anything too seriously.
Old 07-23-2020, 02:21 PM
old28's Avatar
old28 old28 is offline
Well Bob, you new what his answer would be
Hope she runs good on the 2nd, have fun, stay safe in those "New Belts"
Are both you & Dave going to make a few passes?
Bad Day On The Drag Strip Is Better Than A Day In The Stands.
Old 07-23-2020, 03:18 PM
Only took my cars to the track a couple of times & had no clue seat belts expired... go figure! They don't expire for street racing do they... asking for a friend!
Old 07-23-2020, 09:07 PM
If your car is quick enough to require a seat belt/shoulder harness, you must use a s.f.i. 16.1 assembly, properly installed. It needs to be replaced every two years. They are date coded when purchased. The theory is that UV rays degrade the material. Lots of people think it is simply a money grab. Some harnesses can be sent to the manufacturer to be rewebbed. But it costs almost as much as buying new.
The really fast street racers you see on cable TV all look to have pro built chassis with NHRA cages and safety equipment. Probably more important on the street where traction is sketchy and the roads are narrow.
Old 07-24-2020, 03:45 PM
Skip, I can send the old belts to you. I might have a couple sets around if anyone else wants a set. Maybe pay postage.
Old 07-24-2020, 04:20 PM
Skip's Avatar
Of course I was joking, but I would be delighted to accept your offer. My next project would look great with them. Happy to pay postage. I'll PM you.
Old 07-26-2020, 12:29 PM
old28's Avatar
Bob, I sent you a PM
Old 07-26-2020, 05:30 PM
Tom, I didn't get it. You might have to try again.
Old 07-27-2020, 11:57 AM
old28's Avatar
Bob, Sent another PM today.
Old 08-11-2020, 06:57 PM
In the never ending quest to go quicker, I took the center carb apart and ventured out to The Carb Shop. The owner is very experienced and gives free advice. Bought some jets two sizes richer because some of the plugs indicated it was a bit lean. We'll be running in two weeks so I'll fiddle with timing. Dave has his starting line technique perfected. We should get in the 11.20's. To break into the 10's it will probably require some head porting and a larger cam.
