Old 05-06-2021, 11:00 PM
MercuryMac's Avatar
MercuryMac MercuryMac is offline
Builder Junky!
I like the corners also.
Old 05-08-2021, 08:16 PM
Default Daniel Boone was a Tractor and a Trailer
Gradually removing the deck from the old trailer. Lots of welds to cut with a Zip wheel. I want to save the decking, which is formed channel. I'll use it on the new trailer but will just use two strips turned upside down for tire channels. Should work good. Here's a shot of the Dodge frame lurking in the grass, waiting for me to start the '30 Dodge pick up build.
Old 05-11-2021, 09:52 PM
Got the side rails back from Jerry the Sandblaster. Ventured into riot torn Minneapolis and picked up steel for the trailer. Welded patches on the side rails where they were thin.. Moving right along. But I probably will need more steel.
Old 05-14-2021, 02:45 PM
The trailer is widened 15". I patched the original frame where it was thin. Next will be the extensions on the rear. The rear end of the dragster is narrowed so the channels will be widened to the inside to accommodate the difference. As you see the blue channel now it fits the width of the dragster front end. It sounds sadistic, but I'll cut the tongue and the diagonal supports off the old trailer and weld them on this one.
Here's a pic of what my next roadster will look like (this winter).
Old 05-14-2021, 03:17 PM
Torchie's Avatar
Torchie Torchie is offline
All nice.
Especially the roadster.
Old 05-14-2021, 04:58 PM
soltz's Avatar
soltz soltz is offline
The Rat Captain
Talking
^^^^^^^^^^^YEP
Be Safe
and
Be Creative
Old 05-15-2021, 06:17 PM
Default Slow but Steady
Did some trimming and fitting on the channels. Just about done with the wide part at the end where the slicks will sit. The channels will go to Jerry the Sandblaster to get cleaned up. Lots of cut off wheel work, grinding and welding. Here's the body I put together out of spare junk. It will be the basis for the roadster shown yesterday. But first, I'm going to take the Mustang II suspension out of the Renault and put a straight axle under it. Gasser style, but not nose bleed.
Old 05-15-2021, 06:21 PM
Misbehaven's Avatar
Misbehaven Misbehaven is offline
Default Selling anything
I see a sad one that needs to be on the road or strip
I JB weld most everything and Bubble gum the rest
Life is to short to do it right the first time 🤥
Old 05-15-2021, 08:32 PM
I don't know which one you are referring to. The Anglia is ready to hit the road right now.
Old 05-16-2021, 08:32 AM
I don't know what it is about the Renault Dauphine's that I like but, I do.
