Old 07-18-2022, 09:35 PM
Originally Posted by Bamamav View Post
Sure he can. I enlarged the center hole on a pair of steel wheels with a 4" grinder. Took a minute, but just kept grinding and test fitting until it slid on all the way.
Aluminum might be harder to grind because it's so soft and will load up a grindstone quick.
I have to increase the hole diameter by almost 3/4" inch. The aluminum is a half inch thick. Spent 2 hours with an aluminum cutting burr in a die grinder and made it about a quarter of the way. It just isn't worth it.
Old 07-18-2022, 10:28 PM
zzrodder's Avatar
zzrodder zzrodder is offline
How about putting a wood or aluminum plug in the center and using a hole saw of the right dia.?
Old 07-19-2022, 07:53 AM
Use a deburr bit in a die grinder with as heavy spiral cutting serration as you can find. It'll cut like butter.
Old 07-22-2022, 05:47 PM
Okay, you guys shamed me into trying again. I made a drill guide out of 1/4" by 5" plate that bolts to three lug nut holes. Bought a 3 1/2" hole saw blade and commenced to drill. The batteries don't want to turn that large diameter blade very long. I get lots of rest breaks. It's going to work though.
The pilot hole is centered but the hole saw wants to hunt off axis a bit.
Old 07-22-2022, 10:45 PM
soltz's Avatar
soltz soltz is offline
The Rat Captain
Thumbs up
It’ll get there
Be Safe
and
Be Creative
Old 07-23-2022, 06:57 AM
Bamamav's Avatar
Bamamav Bamamav is offline
I didn't think about using a hole saw, great idea. What you need is a good 1/2" corded drill to run it though. My old one took a dump, so I picked up one at Harbor Freight. I'll have to say I was impressed. I didn't really like their electric stuff before, but this one seems to be as good or better than the Black and Decker it replaced, time will tell. I use my battery drill a lot, but for big jobs you just can't beat a good plug in tool.
2023 calendars available here:
https://www.zazzle.com/2022_fat_fend...46680814180838
Old 08-06-2022, 09:42 AM
Goldcar1967 Goldcar1967 is offline
Old 08-28-2022, 10:14 AM
We ran at Brainerd this weekend. Set a personal best of 11.28. Next is the Fall-Out at Rock Falls, Wi. in mid-September. This winter the digger will get a beauty makeover. I'll also try to find a few more ponies. Would love to get in the 10's. Last pic from left to right; me, Dave and Jerry
Hard to believe this thread has had over 650,000 views. Thank you everyone.
File Type: jpg 301618592_6017885071572640_172543862831756782_n.jpg (153.9 KB, 26 views)
Old 08-28-2022, 05:43 PM
Instead of zoomies run the 6 into two and run them in the order they fire in.
Should be good for 1 ta 2 tenths
Old 08-28-2022, 07:07 PM
smallfoot's Avatar
smallfoot smallfoot is online now
Congrats on the PB!
