Go Back   Rat Rods Rule / Undead Sleds - Hot Rods, Rat Rods, Beaters & Bikes... since 2007! > Frame/Suspension/Brake... Talk & Q&A
Frame/Suspension/Brake... Talk & Q&A All things... Frame/Suspension/Brake
Old 06-01-2017, 03:47 AM
DozerII's Avatar
DozerII DozerII is offline
I guess I really should have updated this with the upgrade.
Glen
My 29 Essex Build http://ratrodsrule.com/forum/showthread.php?t=34026
Don't give up, it's far too much fun once you can drive it.
Old 06-01-2017, 09:45 PM
TIMOTHALE TIMOTHALE is offline
Default New arms Question
from what I am reading the aftermarket arm fit a 50;s F i spindle. For reference I have a couple F I axles squirl[ed away for future projects.
Tie rod problems like you described are usualy caused by not having the center lines correct, the tie rod can be bent and reshaped but the threaded portions should be on the same centerline , also when the arms are heated and bent the taper center lines should not be changed. I had that problem years ago when I used Olds spindles adapted to a ford tube axle.
Old 06-01-2017, 09:47 PM
from what I am reading the aftermarket arm fit a 50;s F i spindle. For reference I have a couple F I axles stached away for future projects.
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
