Go Back   Rat Rods Rule / Undead Sleds - Hot Rods, Rat Rods, Beaters & Bikes... since 2007! > Frame/Suspension/Brake... Talk & Q&A
Frame/Suspension/Brake... Talk & Q&A All things... Frame/Suspension/Brake
Old 03-31-2017, 06:32 PM
akatao akatao is offline
all the symptoms point to a master I've had bad new masters as I'm sure others have.
Old 03-31-2017, 07:04 PM
53 stickfigure's Avatar
53 stickfigure 53 stickfigure is offline
Ive learnt that all master cylinders and other parts are not created equal. I used to buy from the chain stores, autozone, advance, o'reilys, but not anymore. Nearly every part I've bought from these places, I've returned or had to replace. I go to places like napa and parts plus stores now. You pay a little more, sometimes quite a bit more, but the quality is alot better.
Old 04-01-2017, 07:13 AM
DozerII's Avatar
DozerII DozerII is offline
So yesterday I took the original master cyl apart to look inside. Other than a little crud in the very bottom it was spotless, not a mark in the bore, all the rubber cups look good and the bypass ports clean.
I spent about two hours watching youtube videos about prop valve and I'm really leaning that way. The one I have is off a 75 Caprice that sat for at least 10 years, I'm thinking something in there is moving just enough at certain times to cause the problem. I'm going to order one and I have three new hoses coming Monday.
Glen
My 29 Essex Build http://ratrodsrule.com/forum/showthread.php?t=34026
Don't give up, it's far too much fun once you can drive it.
Old 04-01-2017, 10:05 AM
oldmanb's Avatar
oldmanb oldmanb is offline
What are you using for residual valves? I had the same problem and ended up using a 2lb and a 10lb.
Old 04-01-2017, 10:59 AM
DozerII's Avatar
I'm not using any residual valves.
Glen
Old 04-01-2017, 01:23 PM
oldmanb's Avatar
If your master cylinder is below or equal to your caliper bleeders you will definitely need them. They hold a slight pressure in the lines, and will keep your pedal up. I ran into the same problem on my 31' a few years back. You being a Westerner , should able to find a pair from an old Venture or Uplander van,(no rust) , us easterners have to buy Wilwood
Old 04-01-2017, 03:45 PM
DozerII's Avatar
The master is about 8 inches above the caliper bleeders.
Glen
Old 04-01-2017, 04:16 PM
oldmanb's Avatar
I went back and checked out that post on your build, and saw your mc location before I posted . ALL masters c's that are below need them, (Horton Hot Rods info) ,most above don't, but I'd say that's your problem. All GM minivans that I've worked on have them from the factory, their mc is high.
Old 04-01-2017, 11:28 PM
MercuryMac's Avatar
MercuryMac MercuryMac is online now
Builder Junky!
I've given this occasional braking problem some thought. I like detective work. Sometimes brake fluid leaks out of your system and causes your pedal to go to the floor. It's not going out onto the road, you say, so where is it going? It has to be going back into your master cylinder reservoir. So you don't actually loose it but it squirts out of the pressured part of the system, [between the master piston and the wheel pistons]. I kept coming back to, a foreign object [a flake of rust, a piece of wire, or a wild oat hull] in your fluid, and once in a while it gets between the master cylinder and the piston rubber and causes a leak back into the reservoir. But, now I thought of something else. Have you got any part of an anti-skid braking system on your brake lines? Maybe it's letting off pressure. I've never tracked this kind of brake line so I don't know if the pressure release is in the master cylinder or somewhere else. Food for thought, anyhow. Good luck.
Old 04-02-2017, 05:40 AM
DozerII's Avatar
Thanks for the great info oldmanb, one I get the new prop valve and hoses on we will see what happens, if there is still a problem I guess it's residual valves.
Thanks Mac I'm thinking because everything is new except for the hoses and the prop valve one or all of them is contaminating the system. All brake parts are pre 1980 design so no ABS items.
I drove it yesterday 220 kilometers and never had an issue ( but I was on edge every time it came to braking)
Glen
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
